EXT04
10-23-09, 08:54 PM
04 EXT.
1. My key fobs are not working. I believe the battery is fine because both fobs are not working. When I bought the truck it was in working order. I don't know why it stopped. I did reprogram the fobs and it still doesn't work. I checked the fuses and they are fine. When I click the lock from drivers panel then close the door I see the cluster security light is flashing. Maybe it's a bad BCM? I'm sick of having to manually unlock the darn doors. Any ideas?
Also I have another problem lol.
2. You know the perimeter light? Mine doesn't work! What the hell! I did set the perimeter on but it still doesn't work. Both bulbs and fuses are good.
3. Heated seats. When I push the button for both heated seat and back, after like 10 seconds it turns off itself. If I use only the heated back button it works. Bad heated seat module???? Any help, I would appreciate it. Thanks.
