2005ESCALADENJ
10-23-09, 12:29 AM
Hello,
1st time poster here. I just purchased an 05 Escalade *(Base model) with front end damage. I need a drivers side frame rail part. From the tow hook back a few inches. I'll try to add an image. Can anyone tell me where I can find this part and what the part is called. I'd like to avoid the dealer if possible.
Any help would be apprecited !
Thank you
I tried to upload but my images are too large and I don't know how to make them smaller. If anyone wants to the the part, please let me know and i'll e mail them.
Thanks
luxurylife33
10-23-09, 01:35 AM
use photobucket to resize ..... your best bet is a junkyard. They will cut anything out of a junk car
2005ESCALADENJ
10-23-09, 01:51 AM
Thanks --- i'll look into photobucket.
I called around and can't find anything. I was hoping someone here would be able to direct me somewhere that would have it new or someone here able to sell it.
luxurylife33
10-23-09, 11:16 AM
is it a bolt-on part or is it a cut and weld part?
2005ESCALADENJ
10-23-09, 12:20 PM
I am not 100% sure. The dealer says they have a part but I haven't been able to get there to see it. There are none in my area. My body guy has been checking yards. Said the dealer would charge $900.
The part the dealer says they have cost $360
I have an image if you wanna see it.
zerocarpileup
10-23-09, 01:25 PM
I think i might have the same problem. i ran into a pole a few years ago on my drivers side at the tow hook and although not noticeable at first, i cant go bigger than 24s since my wheel on the driver side looks pushed back towards the rear of the front fender. there's only about a 1" clearance compared to the almost 2.5 on the passenger side.So i don't know if the fenders whacked out or if i have actual frame or chassis damage. Is this similar to your problem?
2005ESCALADENJ
10-23-09, 08:10 PM
I don't know much about frame damage. My body guys says my wheel base is not out of alignment. So I guess if you measure your wheel base you might know better. I bought this with front end damage, I have all the parts pretty much except this frame part.
www.car-part.com best you can go there. I did buy front drivers rail there. It was for a VW Golf GTI. They cut the size that I needed and shipped it to my door.
