View Full Version : Lube point question
oldworld
10-22-09, 01:18 PM
I noticed while under the truck this morning that there are two (2) lube points on the front end where the fill filltings are facing up. I had a heck of a time getting the grease gun fitting on the the top of one, but there is no way in hell to get it on the other. They are both in line, but the one on the passenger side does not have enough clearance. Do they make some sort of 90 depgree grease fitting? Maybe even one that attached to the grease gun?
How do you guys get at that one fitting??
THANKS
coralreef35mm
10-22-09, 05:26 PM
You can get a 90 for your grease gun..Kind of slides over it
Or, just change out the zerk with a 45 or 90
oldworld
10-22-09, 09:43 PM
Is it easy to simply change out??? Can I buy the replacement at any auto parts store???
THANKS
sk7
10-22-09, 10:26 PM
Yep! Take it off so you can compare thread sizes to make sure you have the right one. That's a good idea to replace em! I've got an adaptor on the grease gun for the 2 on the pitman arms, they are rather hard to get to.
oldworld
10-22-09, 10:45 PM
Those are indeed the ones I am referring to. THANKS
Maybe I will just buy to right angle adapter for the gun.. Auto Zone should have that????
luxurylife33
10-23-09, 01:42 AM
How many lube points are on the escalade? And where are they? I have never done this before, I was reading somewhere you have to get rid of the old grease before greasing?
coralreef35mm
10-23-09, 11:08 AM
Autozone might have the zerks and/or lube tip..Also try a hardware or tool store.
Zerks come in metric and standard and different thread sizes so be sure to get thr right one..
Someone on here probably has the link to the lube points..I think there are 11
Don't overfill the rubber bladders for sure.
sk7
10-24-09, 02:38 AM
http://www.gm-trucks.com/resources/how-to/2009/01/22/locating-and-replacing-all-11-grease-zerks/
oldworld
10-24-09, 08:54 PM
THANKS SK as always.....great link to pics
