brianroark
10-21-09, 02:55 PM
Whats wrong, p0420 code on my car, cat is about 3 months old (cheap magnaflow). I floor my car all the time at least a couple of times a week but i haven't engine braked from 2nd gear, will beating the car a lot work for the wot? i know i should but I'm a speed demon and my play car isn't done yet.
what could be the prob here.
new to recent, ac plugs, ac wires, intake gasket, air filter, fuel injector cleaning. etc.
I was driving up north and floored my car a couple of times, it looked like coolant steam was spraying out of the rear pipes (night time), was probably carbon or moisture, or just from being cold out.
this has happened before a month ago when it was warmer though, that time i thought it was the slick roads.
i used the engine block tester kit, blue fluid that turns yellow if carbon is present from sucking coolant tank air and it stayed blue after 3 retests.
i have a small coolant leak that I cant find?? kinda freaky hearing about all this hg stuff. I don't think my head threads have corroded yet though. Do all the n*'s have head gasket issues after time because after all the abusing i have done to this car not intentionally, just a hot headed speed demon. i would think the heads would have opened up a little already.
so what would cause a p0420?
I have a tech 2 so i could check the 02 sensors and other variables if that will help.
Thanks,
Brian
ps. hey i have casino cash, whats this stuff guys? :)
IT guy that is a idiot.
Thanks,
Brian
