jtlahr
10-20-09, 02:04 PM
I have a 99 SLS and am wondering if I can put it into a 99 STS? Does anyone know or has anyone done this?
Thanks!
Thanks!
| View Full Version : SLS engine and trannie in a STS? jtlahr 10-20-09, 02:04 PM I have a 99 SLS and am wondering if I can put it into a 99 STS? Does anyone know or has anyone done this? Thanks! kjhansen 10-20-09, 04:26 PM Should be a bolt-in although I've never done it. From what I've read, they're the same engine and transmission--the main difference is the camshafts, which is not a player for the installation--although you might want to use the SLS computer too. Also, the radiator I got for my SLS was an STS radiator and it has oil cooling line attachments on the passenger side, and my SLS has a separate oil cooler hanging in front of the radiator and A/C condenser. So there might be some minor adjustments you'll have to make. Take into consideration that my SLS is a '95 and your cars are both 99's so a lot might have changed... Ranger 10-20-09, 04:57 PM You'll have to swap the PCM with it. | |
