View Full Version : 67 deville need windows to work
67badazillac
10-19-09, 09:58 PM
new here and need some help. when i purchased my 67 sedan deville the back two windows wouldnt move from the driver swithc or thier own door switch. the passanger would only work from the driver, . and the driver window would work but a worn gear keeps it from going all the way up. took it to an electrical place hoping that atleas one window would be an easy fix but instead got a list of parts i needed to totaling a little over 500 plus another 500 for labor. i would rather do it myself but i was wondering if i need all those original parts or if any of those universal power window kits would work. i seen them adverstised in truck magazines all the time for trucks with manual windows. cant i just use this on my caddy?
csbuckn
10-19-09, 10:15 PM
I dont think any universal kit will work. What parts did they say you needed?
77CDV
10-19-09, 11:15 PM
I think in 1967 your windows are still hydraulic, not electric, so you'd have to redo a lot to use those adaptor kits.
67badazillac
10-20-09, 12:14 AM
they said i need a new master window switch, left front regulator, left rear window motor, and lock out switch
67badazillac
10-20-09, 12:17 AM
pyroman
10-20-09, 06:05 PM
1967 did have electric motors, 1959-1968 used the same motor, You can get the motors from Rockauto $100 each including a core charge.
E-bay is also a good place.
Dont forget scrap yards, a lot of years used the same switch
my 65 sedan windows dont work yet, it another job that needs doing, it can wait until the spring.
DrFunky
10-27-09, 01:19 PM
Im having the same problem, none of my windows go up or down and none of the seats move.
cadillacbart
11-01-09, 11:02 PM
The windows and seat are protected by a cicuit breaker that is plugged into the fuse box. Try pulling it out and reintalling it. It is a silver rectangular box with two post connectors that push into the fuse box.
outsider
11-02-09, 10:53 AM
Not sure if this will work for you but I fixed the windows on my 69 cadillac this weekend by doing the following. very simple and free...
1: take off the door panel
2: find the motor (usually on the bottom of the door I think.)
3: hold down the window switch so the window would be going down if the motor was working.
4: tap the motor with a hammer a few times.
This actually worked. My girlfriend's father, who's helping me fix up the '69, suggested this and I thought he was crazy...turned out it worked and i now have functioning windows and it didn't cost a single cent. :D
phillybusa
11-03-09, 01:57 PM
Remove your motor from the door panel and make sure the glass goes up & down freely.........I bought the $140 motor for no reason other than bad troubleshooting.
Good luck
