HUF
10-18-09, 05:50 PM
My car jerks quite noticeably at start up. Is it common? Do engine mounts fail commonly on these cars? Replacing does not seem to be either difficult or expensive.
Thanks!
Thanks!
| View Full Version : Engine Mounts 95 FWB HUF 10-18-09, 05:50 PM My car jerks quite noticeably at start up. Is it common? Do engine mounts fail commonly on these cars? Replacing does not seem to be either difficult or expensive. Thanks! csbuckn 10-18-09, 08:32 PM you can usually tell if the motor mounts are bad by watching the motor as someone starts it or puts it in gear. If there anything like the ones on the 90, they can be a pain to line up HUF 10-19-09, 02:53 PM When I am power-braking, the left headlight is going up about 1.5". The engine does not move with respect to the body. Is it normal? csbuckn 10-19-09, 09:49 PM Not sure what you mean by that. Has your throttle ever stuck, like kept reving after you let off the gas? HUF 10-19-09, 10:27 PM Not sure what you mean by that. Has your throttle ever stuck, like kept reving after you let off the gas? The throttle is perfect. By power-braking I mean, starting engine, shifting to D with my foot on the brake pedal firmly and pressing gas pedal. The left fender of the car lifts up about 1.5" during that procedure. | |
