View Full Version : Can this trim (photo inside) be taken out and painted? On my Seville STS (1996), I want to know if the silver trim comes out or if I have to paint it while it's on the car. The back bumper piece is fading and the front pieces are as well. The trim is shown in this photo which I stole from another post because I am too lazy to find my own photo. :)
If this can be taken out, do you have recommendations? Thanks in advance.
http://www.cadillacforums.com/forums/attachment.php?attachmentid=53124&d=1255674422 submariner409 10-17-09, 04:40 PM Aren't those strips secured with double-sided 3M adhesive tape ? Maybe a long session with a warm hair dryer..............ask your local good body shop. They do that stuff every day. Netjive8 11-01-09, 06:54 PM Did you ever figure out what to do about those trim pieces? I'm interested in fixing the same thing on my car. Did you ever figure out what to do about those trim pieces? I'm interested in fixing the same thing on my car.
Not yet. I haven't been to the body shop in a while. I was there getting an accent put on the trunk deck two weeks ago. I'll have to stop by sometime and see.
If you find out first, update us in this thread. I'll do the same. Okay, it's held in with tape. The stuff comes off when you pull it. Just be careful not to scratch the body of your car when prying. You might use a cloth behind whatever it is you use to pull the molding up.
I have purchased black trim to replace the chrome trim. It's nothing OEM, it's aftermarket stuff that's the same size and everything. Also be sure to get all the tape from the old stuff off completely, so that the new stuff will stick well.
I can provide the name and item number when I receive the trim. I bought it at a local shop for about $20 per roll (18 ft) times three rolls. $60. It comes in chrome and black, whichever you prefer. Now that I have the trim, it is made by StyleGuard (Cowles StyleGuard). The package says wheel molding. The back of the package says:
T3602C
Black
3/8" x 18', 9.5MM x 5.5M
Wheel Molding Round Black
You can buy it online if you Google it. It's available in BLACK, CHROME, and GOLD. Here are my results:
$13.77 - http://www.woodys-auto-supply.com/performance-accessory.asp?prod=C1P-T3602C
$15.48 - http://www.fixthisride.com/showproductdetail.jsp?prod_id=48094&mid=C1P&pid=T3602C
$19.00 - http://www.autoworldaccessories.com/script/newcategorypage.asp?category_id=1381
Info directly from the manufacturer: http://www.woodys-auto-supply.com/oem-catalogs.asp?type=performance&cat=C1P&support=YES (can't buy on their site)
REMOVAL OF OLD TRIM
This is fairly easy. It's held on with double sided tape. We'll see which is better: old or new (the old has held strong since 1996). I used a butter knife and a cotton terry cloth. Use the cloth to prevent scratching by placing it under the butter knife the best you can. Once you've loosened the trim, protect the paint with more of the cloth. Wiggle a bit, and you'll then be able to grab a hold of it and SLOWLY peel the trim off.
Be careful on the side of the car, as pulling without applying a little hand pressure to the door panels may pull the panels loose. You don't want that. You must apply hand pressure (apply pressure with one hand and pull trim with the other) to those door panels.
It's easier than it sounds.
APPLYING NEW TRIM
Some trim is tucked in which is excellent because you won't have to cut at an angle -- the body will take care of it for you. With other trim, you will need to cut at an angle. I am keeping my old trim so I can measure and angle the new trim properly.
Now follow the instructions on the product's back side. I'll post tips if I have any. I am waiting until tomorrow to put the new stuff on since it needs to be at least 65 degrees F outside. Netjive8 11-04-09, 07:25 PM Wow, thanks, this is going to help me out a lot. :worship:
A few questions, if you don't mind:
Did you have to remove any tape residue from the old trim?
How close does it look to the original trim? I only need to replace one door right now, so I hope it doesn't make the trim on the other doors look bad by comparison, because the trim on my other doors is kinda faded. I guess I could always replace the trim around the whole car.
Thanks again for the valuable info. :thumbsup: I look forward to seeing how it turns out. Did you have to remove any tape residue from the old trim?
There is tape left over from the old trim. I will take it out tomorrow when it's bright again. After that, I'll update you on the process: whether it was easy or hard. It should be fairly easy because I pulled some off with my fingers.
As for the appearance matching the OEM trim, I am not sure yet. I'll compare them tomorrow, though I would lean to suggest replacing it all-at-once. For $60 (3 packs x $20), that's not bad at all. You can grab it even cheaper online.
I'll post a photo when it's done. The car's not so hot because the factory wheels are on for the winter, but you'll at least see the trim. :) IMPORTANT
This trim does not fit. It's too big. I just ordered 5/16" instead.
The item I ordered in 50 FEET is: 1000A42 from http://www.mcmaster.com/#orders/=4dhzr8. They're in Illinois. The manufacturer is Trim-Loc (product page: http://www.trimlok.com/SearchResult.aspx?CategoryID=31). They only sell in 500' and higher, though McMaster is a retailer who sells smaller quantities. There are probably other retailers that sell in other colors. Call Trim-Loc to find those retailers, or use their Contact page to find alist: http://www.trimlok.com/contact.aspx.
Taking the old tape off took about two hours. I used some "Label & Sticker Remover (http://yhst-13811118617756.stores.yahoo.net/dom-slsr.html?productid=dom-slsr&channelid=FROOG)" from Advance Auto Parts and a flat head screwdriver. I didn't even cover the screwdriver, just used it bare to the paint. The panels are fiberglass (or similar) anyway.
I'll be back with photos after the install... I ordered that trim overnight, so it showed up before I woke up this morning. 5/16" is perfect. The install went pretty well. I peeled the backing of the adhesive as I went along to prevent myself from screwing up, also using my fingers to press on the new trim as I applied it. It was simple.
For the back bumper, I had my brother hold the trim roll because I cut the first too short. I recommend having someone hold the trim roll as you move along the back bumper, THEN cut once you reach the end. The design of the car is nice because the trim tucks under the body so that you don't have to cut perfectly.
Before applying the new trim, I used a wet cloth to remove excess dirt and tape residue (from the old trim).
So far everyone I have shown likes the black over the chrome. Bear in mind I also have a red and black color scheme. Questions or comments, just post.
Here are some photos:
http://i36.tinypic.com/10sabk3.jpg
http://i33.tinypic.com/16c03g0.jpg
http://i33.tinypic.com/2cprsbb.jpg Netjive8 11-14-09, 02:28 AM Thanks for the pics, I'll have to see if I can find the chrome equivalent and try this myself. Netjive8 11-15-09, 03:54 PM I'm having trouble finding the 5/16" chrome version. I know you said that the 3/8" was too big, but do you think that 1/4" would work? Thanks. | |
