View Full Version : 2009 DTS Issues River_Rat 10-14-09, 06:15 PM I apoligize if these two items have been covered previously. Just purchased a pre-owned 2009 DTS and am waiting on the owners manual but have two issues if someone can help. 1st is, that when the radio is on and I shut off the car, remove the key and open the door it continues to play. On my previous 2003 DeVille it would stay on for 10 minutes or shut off when the door was opened. 2nd is, that I can't seem to program the Homelink. I reset by holding both outer buttons until the lights flashed but can't seem to get the unit to accept the code from my handheld unit. Have never had trouble before with any vehicle including the 2003 DeVille. Where is the best spot to place the handheld unit when trying to get the Homelink to read the code? Thanks for the help.
Jim Superjim 10-14-09, 08:09 PM Can't help you with the Homelink, but it sounds like there is definitely a problem with the radio.
if you have removed the key, it should turn off when you open the drivers door.
Texas Jim River_Rat 10-14-09, 08:47 PM Thanks for the reply. Now that I think about it, the time (digital clock) stays on also and I haven't really checked to see how long, but I'd bet it's probably 10 minutes. This leads me to believe that the auto-shutoff is working but not shutting off when the key is removed. It still has plenty of factory warranty left so I guess I'll let the dealer figure out what's wrong.
Jim Southern 10-14-09, 09:28 PM OK try this.
If you cannot frind the book for the Garage door opener (GDO)(most of us can't..................) Get a ladder and see if there is a small button visible on the GDO. If there is try this......
Push the left and right buttons on the homelink in the car until the homelink light flashes rapidly.
That clears any old codes that were in there from the previous owner.
Park the car in the garage or just outside the garage.
Go back up that ladder and push that little button on the GDO(If there is a GDO god, it will be labeled "Learn" or some such............) If the door moves...........wrong button.
You will have about 30 seconds to get down from the ladder, get in your car and depress the button in the car you want to use.
You need to hold that button until the homelink light flashes rapidly.
That can take 30 seconds or so.
When it flashes, quit pushing the button.
It is now programmed.
When you push the button now the door should move.
Note - this button may react slower than your old buttons on the 03. That's normal. Superjim 10-14-09, 10:41 PM Southern,
Very good explanation of programming the GDO.
I knew better than to even TRY to answer the gentleman, because I could not remember all the steps.
Now that I read it...I remember having to do exactly that...get on the stepladder and push the button on the back of the GDO.
And...my Homelink button does have to be held down for a couple of seconds to activate the GDO.
The remote that came with the GDO...acts INSTANTLY.
Texas Jim River_Rat 10-15-09, 09:31 AM Southern & SuperJim:
My bad for not being real clear on what the problem is. I'm familiar with the "learn" button on the GDO. The issue is that after I clear the codes in the vehicle (by pressing the two outside buttons until they flash) I can't get the Homelink in the car to learn the code. What I've always done in the past (after clearing old codes) is to press & hold the handheld remote button I want to program, holding it next to the Homelink overhead in the car and at the same time press & hold the Homelink button I want to associate until the Homelink flashes rapidly. At that time I can go through the "learn" procedure that Southern explained. I can't get the Homelink to learn. I've tried holding the handheld remote everywhere near the Homelink until my fingers ache.
Thanks,
Jim TulsaVic 10-15-09, 12:48 PM Another instance of having an older garage unit that doesn't have rotating codes? Where you have to read the code inside the remote and then manually program the car? Never could understand why I had to do this with my 08DTS when my 05 300C would learn the code from the remote.... Southern 10-15-09, 01:25 PM OK. Vic may have a point.
If you have an old GDO, you are in deep doo doo and I know I wouldn't attempt to walk you through........
But assuming the recvr does have a rolling code, I did something very radical!!!!
I RTFM.
page 2-53 on the 2008 DTS. (The instructions I gave you earlier is what I did on my 2008 CTS)
This is what I did on my DTS.
Looks like the two units are different..............the DTS does not even call it a Homelink............
1- Push the two outside buttons for 0ne to two seconds only. This does not remove old codes........it just puts the unit into
programming mode.
2- Find the button on the GDO. They say it is usually near the hanging wire antenna.....
Push that button!
NOTE: If there is NO BUTTON. VIC is right and you have an old non rolling code Recvr and this procedure cannot work.
3- Return to vehicle......you have 30 seconds..no need to fall in your haste......press and hold the button on the Universal Home remote that will be used to control the garage door. You may have to hold the button for up to 20 seconds. The light above the switch should slowly blink.
4- WHEN THE GARAGE DOOR Moves, IMMEDIATELY RELEASE the BUTTON!!!!! The indicator light should now blink rapidly
until the programming is complete.
5- press the button again . The Garage door should move now, confirming that it is programmed.
BOL! River_Rat 10-15-09, 03:20 PM Cudos to Southern Jim.....I followed your instructions and it worked perfectly on both garage doors (I do have the rolling codes). What's interesting though is that any vehicle I have had (Park Aves, 2003 DeVille, Toyota Sienna, and a Durango) I've always had to hold the remote garage door unit next to the Homelink and let it mimic the code then use the "learn" button on the GDO. Of well you "learn" something new every day. Now if you could just help me figure out why the radio and digital clock stay on for 10 minutes after the key is removed and the driver's door is opened I'd be golden.
Thanks for all the help from everyone.
Jim tedcmiller 10-15-09, 03:37 PM In my case (2008 DTS with Homelink), the learning process would not work because the old garage door opener (GDO, I believe) not only didn't use rolling codes, it was on a different frequency that is no longer used for GDOs. Lear sent me a unit for free that connected to the same terminals as the indoor push buttons. After that everything worked fine (new car, old remotes, indoor push buttons, etc.). I might note that the three CTS-Vs I have had (2004, 2005, and 2009) all learned the code from the original remote opener. There was no indication that any of these cars use the Homelink system. tedcmiller 10-15-09, 03:49 PM River Rat,
Regarding the question about the radio staying on when the driver's door is opened, I would say that the system doen't know that the driver's door is open. The radio and a few other things remain powered by the RAP feature when the ignition switch is turned to the OFF position and the key is removed. This is normal. The RAP feature keeps battery power going to these things for about 10 minutes if none of the doors are opened. The fact that these things continue to be powered after the driver's door is opened indicates, that the system does not know the driver's door is open. A bad switch perhaps? You don't say what happens when doors other than the driver's door are opened. River_Rat 10-15-09, 04:50 PM Ted:
Good thought! I tried all 4 doors and the radio & digital clock still stay on. The door switches must be okay because the interior lights come on when any of the doors are opened. Guess I'll have to let the dealer figure this one out.
Thanks again,
Jim Superjim 10-15-09, 06:21 PM Opening the drivers door "SHOULD" turn off the radio.
You are right...you will probably have to let the Dealer sort this one out.
On my 2006 DTS, "ONLY" the drivers door opening will turn off the radio.
Darling Wife can open her door, and it has no effect on the Radio.
ANY door opening turns off all other retained power, such as power windows etc...etc, but not the Radio.
Before the Radio was replaced for fading trim, "ANY" door opening, would turn off the Radio.
I have NO IDEA why this Radio is different from the original Radio.
Texas Jim tedcmiller 10-17-09, 06:52 PM I don't think the new radio is any different from the old radio. It is likely that the new radio gets its power from a different source due to the way it was installed. Why the installer would have a choice and why he would choose a different power source is a mystery. In all Cadillacs I have had recently (2004 CTS-V, 2004 DTS, 2005 CTS-V, 2008 DTS, and 2009 CTS-V), the radio is powered off when either the driver or the passenger front door is opened. Superjim 10-18-09, 02:12 AM I don't think the new radio is any different from the old radio. It is likely that the new radio gets its power from a different source due to the way it was installed. Why the installer would have a choice and why he would choose a different power source is a mystery. In all Cadillacs I have had recently (2004 CTS-V, 2004 DTS, 2005 CTS-V, 2008 DTS, and 2009 CTS-V), the radio is powered off when either the driver or the passenger front door is opened.
You are correct.
The NAV/Radio is exactly the same...as far as I can tell.
It is the "OPERATION" of the NAV/Radio when the front doors are opened that is different.
The original NAV/Radio would turn off when "EITHER" of the front doors were opened.
Now, it only turns off when the drivers door is opened.
It's no big deal...just different operation than the original one.
Texas Jim Southern 10-18-09, 02:18 PM On my 2008 DTS non-NAV, like Jim's, ONLY the drivers door being opened will cut off the radio. And I would assume the rest of the accessories such as the power windows, etc. Superjim 10-18-09, 06:14 PM Oddly enough...With the ignition off and key removed from the switch...
If the sunroof is open and I am closing it as Darling Wife opens her door... it stops closing.
I have to re-insert the ignition key and turn it to ACC or on.
If I am putting up my window and she opens her door it stops going up.
If the Radio is on and she opens her door...it keeps playing.
When I open the drivers door...the Radio turns off.
Texas Jim River_Rat 10-29-09, 07:08 PM Well the problem is solved (radio & dash lights staying on with the driver's door open). Turns out there was a loose connection on the "acuator module" in the driver's door. As a follow up, with all doors closed and ignition shut off and key removed the following still work: sunroof, power windows & radio. When the passenger door opens only the radio stays on and when the driver's door is opened all stop working as they are supposed to. However a new problem with the Bluetooth cropped up and I can't believe the answer they gave me. I go through the "pairing" process and I'm asked to input a 4 digit code and then name the device. I ask for a "list" and Bluetooth responds withe name I gave the phone and all works fine.......until I shut off the car. When I go back into the car the Bluetooth doesn't remember my phone. We also tried it with the mechanic's Blackberry and the same result. After some research on their part they said that it will only retain the name if I subscribe to OnStar. I can't believe they would force you to subscribe or else go though the "pairing" process every time. What do you guys think? tedcmiller 10-29-09, 11:36 PM Sounds like a cop out to me. There is no requirement to subscribe to OnStar for the Bluetooth feature to work correctly. That is, once it is paired, it should stay paired. Superjim 10-30-09, 01:23 AM I agree with what Ted said.
They either don't want to or don't know how, to fix it.
Texas Jim River_Rat 10-30-09, 01:39 PM Ted & Texas Jim
Thanks for the replys. I think I'll start a new thread with this issue as it will probably be lost on the current one. If it happens on my car it most likely has occurred before and someone may know what the corrective action is.
Jim | |
