View Full Version : Front end clunk - update
The Wrench
10-12-09, 06:10 PM
Guys, I thought I had posted on the front-end clunking fix; but couldn't find it in the archives.
Anyway, I posted several times last year about my new '08 sounding like the battery or the front wheel was going to fall out over rough roads or railroad tracks. A pretty heavy clunking sound and feel.
Well, I finally took it to the dealer, and asked them to check out the clunk.
They said the brake caliper pins were not sufficiently lubricated, allowing the calipers to click/clunk around when hitting bumps.
I was pretty skeptical, but I can report that after several months, it is definitely fixed! I rotated the tires last week, and sure enough, the caliper pins had been thoroughly greased.
Hope this helps anyone experiencing a similar problem.
DG
G32006SRX
10-13-09, 01:42 PM
This was listed on a TSB...
smithb
10-14-09, 11:10 AM
I just changed the rear pads on mine. The pins didn't look overly greased. Do you know what kind of grease they used?
G32006SRX
10-14-09, 02:22 PM
I always used this for my cars. I haven't done the brakes on my SRX yet.
http://www.permatex.com/products/Automotive/specialized_maintenance_repair/brake_maintenance_repair/auto_Permatex_Ultra_Disc_Brake_Caliper_Lube.htm
The Wrench
10-18-09, 07:49 PM
G32, there was a TSB about it? I'll be darn!
I had read thru several of the TSB lists, but I guess the title of the TSB just didn't register with me if I saw it. But it's fixed, and I'm sure gonna use plenty of your recommended lube on a routine basis.
Tks,
DG
73Thumper
11-19-09, 01:16 PM
Would sure like the TSB number on this. My dealer says it was always like this. I installed new rotors and pads - thought it started after that, I do know that just a small amount of brake peddle stops the noise. Thought maybe I put the clips on wrong but hey are good. If there is a TSB# I can have them do it.
G32006SRX
11-19-09, 11:30 PM
2006 CADILLAC SRX Bulletin - Vehicle Safety TSB ID 129970
NHTSA Item Number: 10016555
Service Bulletin #: 3585C
Replacement #:
Vehicle/Equipment Make: CADILLAC
Vehicle/Eqipment Model: SRX
Model Year: 2006
Mfg Component Code: 030000 SERVICE BRAKES, HYDRAULIC
Date of Bulletin: 1969-12-31
Date Added: 2005-09-21
Summary: RATTLE NOISE IN FRONT END OVER BUMPS THAT GOES AWAY WITH LIGHT BRAKE APPLY. *TT
73Thumper
11-23-09, 02:45 PM
TSB info - Perfect - THANK YOU....
