8's on a drag radial
10-12-09, 12:05 PM
Anyone notice there SRX lossing power. My wifes 07 SRX 3.6 just lost power one day after the check engine light came on. I am assuming it was the cam timing advancement that stopped working. Is this chain related, or sensor related?
Please help, this is a salvage vehicle I repaired, so warranty = me doing the work.
Thanks!
The Wrench
10-12-09, 05:30 PM
May well be the dreaded chain stretch, since it's an '07.
But, it could also be something causing it to go into "limp" mode, reducing the timing/power for safety. Is the CE light on all the time? Can you get a scanner and read & post the codes? I think the chain failures usually set a valve timing code.
DG
carguy2009
10-14-09, 02:02 AM
I had a cam sensor failure on my 08 with no loss of power. Dealer found problem on the codes when CE light came on and stayed on. Dealer claimed that they had to shim cam shaft to reduce end play to correct the problem. I have no idea what the actually did. Good luck.
mattias
10-14-09, 10:05 AM
The symptoms seems consistent with what I had and it was the timing chain failure...
