View Full Version : Rear Suspension Help
NvMySi
10-05-09, 12:06 AM
Alright guys i bought this cadillac catera its a 1998, off someone online he hit a curb pretty hard, visually i seen that long bar bent in the rear beside the driveaxle, and the driveaxle was no good as well as it wouldnt move when put in gear, so i went to the wreckers and got those 2 parts, changed the driveaxle (CV) and the bar that is used for allignment, i put my tire on dropt he car and the wheel is still clanted, (rear of the tire is slightly in and the front of it is out, shifted basically, and i lifted it back up again, and shook the wheel and it moves with all bolts tightened, so now its the wheel bearing im assuming right? would the whole hub assembly be bent too? or the lower control arm? i checked and its not visible, just some suggestions would help so i can get this wheel straight cuz its not driveable, dont know what else could be bent under there, the original alloy rim was toast, umm anyways hope you guys can help me out, thanks.
CateraMV6
10-05-09, 12:10 AM
Can you take a picture... because a pic is worth 1000 words and it can help us figure out what we are looking at.
The rear bar you were talking about is used for tow adjustment but if the top of the wheel is out and the bottom is in then the CA is bent...
NvMySi
10-05-09, 02:26 PM
yes your right,but the top of the tire is in and the front of it is out, and the bottom front is in and the rear is out. hope that make sence check out the pics.
maybe because the wheel bearing is loose and i can move the tire in and out freely about half an inch .
NvMySi
10-05-09, 02:35 PM
pictures
NvMySi
10-05-09, 04:00 PM
sorry i dont tihnk i made any sense in the last post what i meant was the half of the front tire sticks out and the half of the rear tire is in. another question is how do you take of the rear rotor and how tdo you hchange the wheel ebaring is it pressed in or bolt on?
and hope you can let me know if i need to cjsut change my hub and bearing, or both along with the lower control arm.
CateraMV6
10-05-09, 07:25 PM
There is a special tool for rear bearing removal and you can look at some of the dealerships they rent out some of theirs...
Otherwise that bent link you removed was preset to some OEM TOE level and I believe that the car needs to be taken to alignment shop so that the link can be adjusted.
Thats what the mechanic at the local shop did to mine to adjust the toe on my car... so I think its just a minor adjustment.
Otherwise if the wheel has some play when unloaded then you have a bad rear wheel bearing... have you compared the driver side to see if similar play is experienced there as well... ?
NvMySi
10-05-09, 07:40 PM
hey yah i compared it to the drivers side and the drivers side is solid, im thinking that when the previous owner hit the curb this hard the wheel bearing just gave out, the question is you think my control arm is fine? and just needs an adjustment as well as the wheel bearing done and thats it? cuz it would need to be adjusted at least an inch or 2. seems a bit too much? is it easier to just replace the whole hub for a used hub rather then changing the wheel bearing? and if so i dont see any bolts that would remove it. umm what are the steps to getting to that rear wheel bearing cuz i took off the caliper and i cant seem to take off the rotor or the back shield. or anything to get to the wheel bearing.
hope you can help otu thanks .
you got msn messenger? would be much easier if not its all good.
Matera97
10-05-09, 11:14 PM
To remove rotor, remove caliper, and that remove rotor bolt, remove rotor. Also if you have your parking brake on, you won't be able to remove rotor. Your rear rotors have shoes inside of them ie your E Brake. If your springs are bad on your shoes, you may need to use a screwdriver to pry the away from inside of the rotor.
NvMySi
10-05-09, 11:34 PM
oh i see, so there is caliper with brake pads and then inside the rotor there is another set of brake shoes? 2 sets of brakes? so just remove caliper, remove the hex screw on the rotor and pry the rotor off? and how do i remove the wheel bearing and change it?
CateraMV6
10-05-09, 11:43 PM
I have one of those tools but its nowhere near me at the moment and I cant see the instructions on how to remove it.
Your catera has Drum Brakes controlled by a mechanical cable and hydraulic disc brakes for normal braking...
I think the rotor is held on with a bolt so that it does not fall off during assembly of the vehicle. Also when the drum brakes rub against the surface they groove it and so you may have an edge which will prevent it from coming off...
I think on the back side there is a window where you can reach and undo the tightening nut which should loosen the shoes and thus release the rotor.
After that i have no idea how the bearing comes out but I know there is a special tool for its removal so it may be pressed in there somehow...
Otherwise if you spin the wheel and you put your ear near the center can you hear grinding noises... ?
Sorry no MSN i have google mail and there is a messenger in there... !
CateraMV6
10-05-09, 11:57 PM
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03839.jpg
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03834.jpg
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03835.jpg
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03836.jpg
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03837.jpg
http://i870.photobucket.com/albums/ab263/MV6Catera/DSC03838.jpg
NvMySi
10-06-09, 12:04 AM
thanks for the pics
now i gotta get a bearing puller, hmm any universal bearing puller will work? cuz i would just go to canadian tire and loan a tool or partsource. if they have. thanks guys for the help. i'll see what i can do this weekend. will keep you posted
CateraMV6
10-06-09, 02:50 AM
thanks for the pics
Good luck man if you need more info out of this manual let me know.
I got it from a buddy in the UK but you can find them on Amazon... look for vauxhall omega repair manual.
NvMySi
10-06-09, 06:35 PM
1 more question, would it be easier to just change the control arm with hub and bearing already in ? (a used one obviously but a good one froma wrecker) or is it easier to just change the bearing?
CateraMV6
10-06-09, 11:40 PM
Yes I think so... the CA is attached by 2 bushings, you will have to pull out those 2 bolts and remove it as a unit... then reinstall the new one with the spring and reattach the shock... and of course new caliper lines etc... should be easier then doing the bearing I think and may even be cheaper.
New bearing is around 80$ I think but check on that too.
If you get a cheap one from the wrecker you may be in luck.
Also if you spot some GTO springs (~20$) on ebay you can swap out the 2 rear ones as they are stiffer and you will get less squad during acceleration.
elvin315
10-07-09, 04:38 PM
I myself would change the trailing arm. The impact likely damaged everything on that side. Swapping the whole assembly will keep you from having to go back again and again guessing what's wrong. I would upgrade the inner and outer trailing arm bushings while performing the swap.
The other trailing arm is probably OK but its bushing are likely trashed from normal wear & tear. Whether you decide to retain the stock rubber bushings, upgrade to polyurethane, or poly/adjustable I'd advice replacing the old bushings. See my suspension write-up:
(click) Catera Suspension Replacements & Upgrades (http://vplatform.11.forumer.com/viewtopic.php?t=5)
ACDELCO Part # 45G11143 {#19195668}
Bushing, Rear Trailing Arm (OEM, Rubber)
http://www.rockauto.com
Pedders Suspensions - GTO IRS Bushing (POLYURETHANE)
GTO IRS Inner Lower Arm Urethane Bush (no adjustments) #EP7023
http://www.peddersusa.com/Solution_GTO.htm
http://wretchedmotorsports.com/images/EP7023_800x533.jpg
Pedders Suspensions - Rear Camber Eccentric (POLYURETHANE)
GTO Rear Camber Kit #5403 (adjustable camber)
http://www.peddersusa.com/images/Pedders%20Part%20Images/5403.gif
http://wretchedmotorsports.com/images/5403_800x533.jpg
SLP Performance: Rear Camber Kit (inner & outer) (POLYURETHANE)
2004-06 GTO: #847-70027 (use w/ #70026 lowering springs)
http://www.jegs.com/i/SLP/847/70027/10002/-1
http://www.jegs.com/images/photos/800/847/847-70027.jpg
Energy Suspension:
GTO Rear Control Arm Bushings: 33188R Control Arm Bushings (POLYURETHANE)
http://www.sfxperformance.com/parts/ENE33188R.htm
NvMySi
10-07-09, 08:08 PM
hey 1 more question guys, on my 1998 catera what is the snowflake do? i press it and nothing happens, i havent driven the car yet because am fixing the rear supsension, but the snow flake button is on the console beside the shifter right under the power window switch.
Matera97
10-07-09, 10:53 PM
The snowflake is for driving in slick conditions, allowing for a better take off. It dissengages when you hit third gear. Its in the owners manual
NvMySi
10-07-09, 11:04 PM
wh the difference between the snowflake and Traction control? is it the same?
Matera97
10-08-09, 01:24 AM
The snowflake controls how much torque goes to the wheels, as traction control engages the brake to the wheel thats spinning.
CateraMV6
10-08-09, 03:16 AM
Well the snow flake is a snow mode which puts the car in 3rd gear when you are stop or moving... then the car will attempt to accelerate by slipping the torque converter and in that case it will have reduced torque and that should provide better acceleration on slippery conditions.
Once car reaches 25-30mph which will be around where the car would normally shift to 3rd gear in regular conditions the light will turn off and the snow mode will deactivate.
As far as the ABS applying the brakes I think mine is either broke or doesn't have it... I got stuck before where only one wheel will spin endlessly without any signs of the other one engaging or the ABS kicking in...
Sometimes when In traffic I will put it in snow mode and the car will sit without moving and when you have to ease forward a slight movement of the gas pedal does the trick...
elvin315
10-09-09, 04:29 PM
Not exactly. It's the Winter Mode button. Press it at a full stop and the computer locks out 1st and 2nd gears until you reach 30 MPH. This reduces the amount of torque to the rear tires and helps prevent wheel spin before it happens unlike the Traction Control that waits to detect wheel spin before activating. After you reach 30 MPH the transmission reverts to normal. The Winter Mode must be manually selected everytime you need it.
NvMySi
10-13-09, 08:50 PM
thanks guys i finally got the suspension on it was a pain in the ass to line up the bolt again for that subfram by the rocker. had to pull it down in order to get the bolt out from the control arm. (trailing arm) but after all its all good i got another issue now i will put here and make a new thread . the problem im having with the car still ever since i bought it off this kid is i charge the battery full and its dead the next day, the battery is good cuz i got it tested at canadian tire, its only 6 months old , the alternator is good as well as i tested it, there is a drainage somewhere is this common? maybe you guys know where it might be ?
CateraMV6
10-14-09, 08:11 AM
Not sure how you go about that... is there some sort of wiring installed for remote start or something of that sort?
Matera97
10-16-09, 11:39 PM
I wonder if this "kid" had an aftermarket stereo installed, maybe power is getting leeched from improper reinstallation of OEM headunit...Could be all kinds of things really, in one of my other cars, I needed to install a new trunk lid. It was a rush job and forgot to tape the ground wire. Drained a brand new battery in under 3 hours.
