: Preorders being taken for the 10 inch ring upgrades.
wait4me
10-01-09, 12:28 PM
OK, final specs are done on the bracketry and the pulley configuration layout.
Pulley cost is $140.
Special idler configuration block. $150.
Belt $55 dollars.
If you already have a 9.5 pulley kit then that is all it will cost.
If you dont already have a 9.5 pulley kit, then add 88 dollars to that price for a smaller idler.
wait4me
10-01-09, 12:43 PM
Im only building 5 idler blocks, so those that want them probably should hurry as i dont know how many more im going to make.
ctsv5005
10-01-09, 06:15 PM
Is it safe? Will we be on a safer side with the 10 inch ring?? thanks.
qictrk
10-02-09, 01:34 AM
Would we need a new tune for the handheld if we are using the 9.5? Cecil............
ctsv5005
10-02-09, 04:27 PM
Yes, 9.5 needs a tune.
qictrk
10-02-09, 04:39 PM
I was talking about the 10". I have the 9.5 tune. Cecil...........
wait4me
10-02-09, 05:18 PM
YES. ANY modification you do needs a new tune. Large or small. If in doubt, just call me and i will tell you weather or not you need to change the tune or not.
But yes in this case, i will need to send you an update.
ctsv5005
10-02-09, 05:21 PM
im not sure about that... answers jess... and is it safer to run 10 inch ring? like the 9.5 is safe. im concerned about the 10.
wait4me
10-04-09, 01:45 PM
As with any horsepower increase, the more you are adding, the less you are going to last. 9.5 is safer than a 10. Yes.
A 10 inch is for the guys that want to run more boost and make even more power.
ctsv5005
10-04-09, 04:17 PM
what is the hp difference between the 9.5 and 10? will we have fuel issues if we go with the 10? thanks.
qictrk
10-04-09, 06:44 PM
Put me down for the 10" pulley as long as you can keep the 9 1/2" and stock programs in the handheld along with the 10". I don't know if or when I'll use the 10", but for the money I don't mind haveing it around. Cecil...........
