pro-five-oh
09-27-09, 01:28 PM
Hi there! I recently got a 1986 Fleetwood 75 Formal Limo for free. The car is clean over all, has a lot of potential. I have searched the forum (which is GREAT) and still have a lot of questions. *Yes, I'll be getting a GM shop manual but I am hoping to get the limo on the road sooner than later. Don't make me beg.
Coolant system over-pressurized when I flushed the coolant and changed the t-stat, car runs hot (I think, no idiot lights came on)...I am miffed as to why the car bubbles and shoots out air when I was trying to purge the air out. It NEVER stopped purging!!!
I am aware of the intake/head gasket problems on this motor, the oil is crystal clear and the coolant looks great when I drained both. The t-stat had some brown stuff on it, though. Car idles great when cold and makes decent power when I drove it on/off the trailer.
Hard to start when warm, stalls when shifting in gear, HIGH idle always. I think this is the coolant temperature sender, but I'll test it first. The Coolant/Fan warning idiot light stays illuminated when I have the key on, but none of the others do. Is that normal?
Power trunk pull down quit working. The glovebox release works, and both fuses are fine.
Where is the RELAY (not fuse) box on this car? The owners manual mentioned its hidden by a panel, but doesn't say where. I need to test the horn relay, as the horn is stuck on.
The stereo's AM/FM tuner and rear seat controls are possessed. Sometimes it works great, other times it will find a station, lock it, but never play it. If you go in the back seat and adjust things, sometimes you can get the tuner to play. It almost seems like a loose ground.
Power locks don't work, but I hear a relay clicking near the passenger side dash. (Is that where the relay box is?) And I hear the same clicking sound when I try to activate the rear door release button in the back seat.
The vacuum pump (under the battery) runs constantly, and most of the hoses were broken in half or crumbling. I replaced them. I pulled the fuse for now, but what does this thing do?
The car has 84,000 miles and it was supposed to be shipped overseas but the deal went cold. Hence why I got it for free. Here's the list of things I've changed to get the car running now:
The majority of vacuum lines
Ignition Module
Coil
Oil
Coolant
Thermostat
Brake fluid
One Caliper/Brake fluid flush
Power window regulator clip
Fuel Filter/Air filter
Serpentine belt
Alternator
Battery
Oh, and I installed a 1991 strut tower brace to triangulate everything. ;)
Ignition Module
Coil
Oil
Coolant
Thermostat
Brake fluid
Serpentine belt
Alternator
Battery
