View Full Version : no rear brakes after pad change
tomaini
07-29-04, 10:06 PM
2000 Sls Changed Brake Pads Front And Rear. After Installation Pumped Up Brakes Then Started Engine Brake Pedal Went To Floor.
Rear Brakes Not Working.....does Anyone Know What Happened?
barge master
07-29-04, 10:52 PM
The recomended way to compress the pistons on an ABS car is to clamp the hose off and open the bleeder first. This is to keep crummy old fluid out of the accumulator of the ABS. I put them in all day without doing this, and so do the guys I work with. The possibility of a problem like yours does exist though,but it is not common. You may find you have to bleed out the accumulator and then the wheels to flush it out. I'm assuming the light is not on in the dash and you haven't tripped the proportioning valve.
Douglass Harroun
07-30-04, 12:34 PM
I had this happen. Turned out the line-banjo washers leaked. Needed more tightening
