View Full Version : Any importance on build date??
4DoorV
09-16-09, 06:04 PM
May be a dumb question, but are there any drawbacks or should I be concerned with buying a CTS-V with a build date back from 12/08????
wait4me
09-16-09, 07:09 PM
Just change the plugs when you get it, That is the only issue i have had with any of them from that build date.
nynd
09-16-09, 07:47 PM
Just curious, what was the issue with plugs - fouling?
wait4me
09-16-09, 08:01 PM
Ceramic loose on the plugs electrodes. The cars where bone stock. One had a bad cat from them.
CTS-V-TWIN
09-17-09, 07:52 PM
Mine was built 12/08, but runs great! Should I be concerned about the plugs and my cats?
SG
Razorecko
09-17-09, 09:05 PM
any other symptoms of bad plugs Jesse ? rich/lean behavior, idling issues, etc
Prof
09-18-09, 06:03 AM
Have we done a build date check on the V's with wheel clicking?
Superior Cadillac
09-18-09, 08:58 AM
I have not had any problems with the ones I sold..
If you buy one built then you saved money since they had a price increase.
nc09v2
09-20-09, 02:03 PM
I got my 12-08 build car in January 09.
I have had no issues with clicking wheels, ultraview noises, or much of anything else folks here have mentioned. Mine has been a really good car and it runs great. Being pre-price increase and saving a few hundred bucks didn't hurt either.
Out of curiosity, Jesse what brand/spec of plugs do you use as replacements for stock cars?
tedcmiller
09-20-09, 05:00 PM
Cars built in Dec. of '08 might not have the new software that allows the radio to stay off when it is turned off before shutdown.
Gary Wells
09-20-09, 05:45 PM
Where's the build / manf'r date located on the car please?
nynd
09-20-09, 05:55 PM
Its on the inside of the door pillar on the drivers side. You'll see build date in month/year on the pillar.
Gary Wells
09-20-09, 06:09 PM
Thanks, nynd.
SlvrBullIT
09-20-09, 08:16 PM
Which plugs should we get.....?
SlvrBullIT
09-20-09, 08:23 PM
The car I test drove had a CEL, when I bought it the Salesman said it was a bad spark plug.... did the leads break off into the cylinder? or was the plugs just burned out? Jesse what was the nature of the issue that precipitated a change of plugs?
ctsv5005
09-21-09, 03:57 AM
NGK TR6 plugs.
homesite
09-29-09, 09:12 PM
My car was built 12/08. The car runs perfect. Should I still replace the plugs?
ctsv5005
09-30-09, 01:39 AM
Same built as mine. I changed them (jess told me to). Now i have even better throttle response, better fuel eco... the car feels healthier now.. He recommended me NGK TR6 copper ones.
Gary Wells
09-30-09, 05:02 AM
NGK TR6: What is the recommended gap please?
Kadonny
09-30-09, 08:36 AM
TR6's only come in one gap and I believe I heard it was fine for the supercharged application. It comes .035.
homesite
09-30-09, 10:59 AM
It seams real tight to get to the plugs. Any suggestions?
Kadonny
09-30-09, 11:26 AM
^^^^ Wondering this also.
4gear70
09-30-09, 11:32 AM
The factory service manual says .040 for the stock ones.
wait4me
09-30-09, 11:53 AM
I usually put them at .44. That is where it seemed to be the happiest with the stock coil dwell times.
Superior Cadillac
09-30-09, 12:07 PM
I have not seen anything on the build dates.
ctsv5005
09-30-09, 06:37 PM
no need to change the gap on tr6 ngk. i put them as it is. so far so good. ngk are 0.44 as jess mentioned above. our stock ac delco are 0.40
Gary Wells
09-30-09, 07:02 PM
Good info, and I really appreciate it, but just to set the record straight and not cause any confusion, that should be .044, not .44, and .040, not .40. And FWIW, & IMHO, tracking cars of a particular make, model, & / or platform is always a good idea as you can approximate the odds of certain issues / problems that are other than isolated incidents, such as what Jesse has discovered here, that CTS-V's with a build date of 12 / 08 generally have plug issues. If it weren't for tracking cars by build date, the vette people would not be able to determine the possibility of whether a particular year of C6ZO6 has needle bearing issues, which one year did or do, and what timeframe has issues with the flying roof syndrome, which is true also. I believe that GM cross referenced the TSB for the flying roof syndrome with a range of VIN #,s and cars within that range of VIN's had recalls. Never underestimate the bean counters, or statistics. Unfortunately, our cars do not have enough #'s to produce a "probable curve" with which to work with. Sorry for the hi-jack.
Kadonny
10-01-09, 09:10 AM
I thought the stock TR6s are gapped at .035, that's what I am reading on a few websites. I'll let everyone know once I get them, I'll check the gap before I install them.
ctsv5005
10-01-09, 06:16 PM
they are .044 for sure. Do let us know anyways.
Gary Wells
10-01-09, 07:03 PM
I know that you guys know, but it is possible, even though doubtful, that a newbie may not know the difference.
Kadonny
10-02-09, 08:41 AM
Gary, what are you asking? Not sure I follow.
Kadonny
10-02-09, 11:15 AM
For everyone's information, the TR6 plugs are gapped .035 stock. Just measured them.
Gary Wells
10-02-09, 12:43 PM
Sorry for the confusion. I know that the gap is .035 or .040, and you know that the gap is .035 or .040, but a newbie might get confused with the gap being represented as .35 or .40.
Kadonny
10-02-09, 12:54 PM
Ahhh, ok. I get it. Still, if you look at a gap guage or any gap chart, you will know 100% that .35 is not the real gap, but rather .035 is the right number. Still, I get what you saying.
Gary Wells
10-02-09, 03:22 PM
I guess that I am a number nazi rather than spelling nazi. No racial slur intended, BTW.
ctsv5005
10-02-09, 04:22 PM
I live in dubai, and here i bought the tr6 which mentions 0.44 on the box of the ngk tr6 spark plugs. Anyways u have to gap it to 0.44 then, because jess said so.. lol
Kadonny
10-02-09, 04:38 PM
Yup, I already gapped them to .044.
Gary Wells
10-02-09, 05:16 PM
What's .035 & .040 in metric?
Kadonny
10-05-09, 08:48 AM
.035 is .889mm
.040 is 1.02mm
