SlvrBullIT
09-11-09, 01:38 AM
Motor oil was easy, even "looked like" a filtermag slot was built right in when I put in the AMSoil EA50 filter on and the "C" mag slid on where a groove was open on the one side. :thumbsup: Old oil was black opaque, feel was bad. very thick. ~6qts out so no consumption as far as calibrated as my eyes are and the little bit that dribbled that i couldn't measure.
Tranny... where do I start.... Pulled the pan after draining it...Low and behold... a magnet in the shape of a washer to the rear of the pan!!! 1.5" with a 1/2" hole int he middle...it's small but there. If you look to the back of the pan and see a divot on the right.. or left side that is where the magnet is on the inside. Still used my filtermag though. The shop didn't have ATL AMSoil so I had to put Dextron VI back in (new fluid btw) the pan. Filled in via plug on the right hand side of the tranny. But I think the tranny is running hot...176F now vs 149F before pan refill Please let me know what you DIC tells you on the Auto tranny if you can guys. While I was there swapping fluids, Chevy guys dropped by to pick up some exhaust piping and told me and another mechanic that GM doesn't advise tranny flush :suspect: and to not do it.....hmmmm
If anyone has swapped tranny fluids, can you please say here or PM with how you did it? Via the cooler lines.... etc
Differential....HOLY COW was mine LOW :rant2::rant2::rant2: Like ~30% low and smelled REALLY BAD and looked and felt really bad. Very black and opaque, I know this is not a guide but felling it on my fingers swirling it around between my thumb and forefinger felt very abnormal, I could have sworn it felt inconsistent. Then the smell.....yeesh. Replaced with AMSoil and 4oz additive. Filter mag added. BTW mag on drain plug as another member pointed out, but I added another.
After buttoning it up and driving it around...the car sounds smoother and I'm missing noise!!! Must have been the diff hummm. The car is just quieter. Launches fine, was paying attention to trans temp when I saw 176F top when I'm usually at 149ish.
Some will wonder why I changed fluids out at 5700 miles....
Well I'm doing a HPDE class on Saturday and I've read some users having issues with diff temps. I figure might as well change them out so I don't have an issue in any case....
