: 2004 Escalade ESV
09-08-09, 10:39 AM
I have a 2004 Escalad ESV and I have been having a intermate starting problem. it appears that the alarm indicator lights flashes and when i shut it off it will not start unless i let it set for about ten minutes. When i try and start it the alarm indicator light flashes showing that it is activated when it is not. has anyone else had this problem if so how did you fix it. i can also be reached on my cell at 240-417-9463 amd my name Is Michael D. thomas
09-08-09, 11:07 AM
is it an aftermarket alarm system? im pretty sure they never had a factory alarm for the 2nd gen escalades.....
09-08-09, 11:57 AM
I had a after market alarm installed had problems and had it removed. It is the factory alarm that I think is still reconizing the after market alarm as if it was still installed. I took it to the dealer that said they fixed the problem and it was okay for a while and it started happening again.
