View Full Version : Alignment values
Cadi Cat
09-03-09, 09:36 PM
Does anyone have a reference to the correct alignment values/specs? (Camber Toe Caster etc...) I think the shop I take my car to for alignments has the wrong numbers.
Thanks!
eastsidercaddy
09-03-09, 10:34 PM
here.. this should be up to date.
http://i45.photobucket.com/albums/f54/PSM_1/83463501.gif
CateraMV6
09-04-09, 12:53 AM
This is what I had when I got mine done...
http://i109.photobucket.com/albums/n50/CateraMV6/MV6%20Suspension/AlignmentSpecs.jpg
eastsidercaddy
09-04-09, 02:58 PM
My first post is the reference from All Data Pro.
Cadi Cat
09-09-09, 07:54 PM
Went to the caddy dealer to get these specs and this is what they gave me: 52517
And here is a copy of the specs from my car:52518
What I would like to find out is why the caster is on the left is so different.
Also the friendly guys at the caddy shop explained to me why the rear wheels wear on the inside. As you are all probably aware on your cars. The guy I spoke to says the chassis/unibody support on the rear of the vehicle over time slightly bows/bends due to the natural weight of the car causing the wheels to have a very negative camber. But as long as you keep the front within specs and tires rotated regularly, tire wear shouldn't be too much of a problem. But the rear control arm bushings upgrade to allow for an adjustable camber may help with this issue.
