: Exchange fluids how often?
SmoothTS
08-27-09, 12:43 PM
I have a 2000 STS I've owned for 5 years, currently has 140K miles. Still has original coolant, brake fluid, transmission fluid. How often should these be changed?
00 Deville
08-27-09, 12:59 PM
I'm sure that you will get some differing opinions on this one... My anal opinion is
Coolant- Change every 2 years
Brake Fluid- Change every 50,000 miles
Transmission Fluid- Go by the life monitor in your car if it doesn't say change it by 100,000 miles change it anyway.
You are way overdue on a coolant change with the history the the N* has with the corrosion on the head gasket bolt holes you would be a fool to follow the GM recommended change times on DexCool.
Submariner409
08-27-09, 01:51 PM
Basically you're way overdue for coolant, and overdue for both brake fluid and transmission fluid.
This time, take it to a dealer and cough up the money for a "Fall Special" package if one is offered. The entire coolant charge gets changed, brake system gets flushed and refilled, and the transmission gets the new DEXRON-VI synthetic fluid.
Not cheap, but you will have the peace of mind that its done correctly as well as have a dealer work warranty and someone to fall back on if something's not right, and a complete coolant, brake fluid, and transmission fluid change is no fun in your driveway.
Coolant: 3-4 years
Brake fluid: 4-5 years (its hygroscopic and absorbs moisture)
Transmission fluid: 5 years/100,000 miles or so
