View Full Version : 84 eldo trouble
DNE
08-25-09, 10:03 PM
hi, this is my first try on the form so hope I;m doing it right.
I recently bought a 84 eldo. cov. after a few weeks started to have trouble, the car shows 91000 mi. don;t know if this is acurate. stated of with engine surging ocasanily shortly after srarted to bog when step on excelarator hard even in park wouldn;t rev up just bog then some time backfire.
what a local shop and I have done so far is check grounds, check fuel presure,cleaned and tightened grounds in dist. checked exhast converter, actualy was bad so eliminated still did it , today was trying to rev. engine it backfired and blew open the muffler, after that it ran better and had more power than at any time I had it , but tonite I stated it and back to same thing drove it about 3mi. tryed rev. it a few times and suddenly stated to run good drove it about10mi all was good, but I never know what to expect when I go to drive it.
ANY HELP WOULD BE VERY MUCH APPRECIATED, I am becoming very frustrated, thanks,. DNE
cadillac_al
08-26-09, 08:34 AM
I always say backfires are caused my ignition problems; especially when it blows up a muffler. I would give it a new cap and rotor and plugs and wires just to rule out that normal stuff. Enjoy.
DNE
08-26-09, 12:38 PM
thanks, will check out youre suggestions,
DNE
steelybill
08-26-09, 02:47 PM
I believe Al is correct about ignition causing exhaust backfire. I did have backfire problems with Chevys because of leaned out mixture, caused by vapor-lock, but your Caddy has an electric pump, so the ignition is the suspect..
carnut
09-04-09, 05:59 PM
If the cat. converter was bad, the pieces from the cat. converter will break apart and plug up the muffler as well. So, you would still have a restricted exhaust system. What was the fuel pressure reading? Should be 9 lb minimum to 12 lb max. under all driving conditions not just at idle. If too lean, it will backfire and have poor power. There is a filter mounted on the fuel pump within the fuel tank that, over 25 years can plug up and cause intermittant low fuel pressure.
