junkpicker
07-26-04, 08:25 PM
just got a 1985 fleetwood. wipers worked and didnt work. ok i have a 1984 sitting for parts. took out wiper swithch installed did not work.ok now i change the wiper motor still does not work. when you push to mist it does click. and they also went up a bout 1/4 of the way and stopped ,that was it. and these worked perfect on the 84. now what,wires? thanks for any help.
barge master
07-29-04, 09:31 PM
I've had the same freakshow with my cars too,sometimes they would just fix themselves all of a sudden. There is a ground connection on one of the mounting bolts, check that. Why a working motor doesn't work in a different car I can't say, but I did fix it on my old 87 by replacing the delay board which is the circuit board behind the plastic cover on the motor. It will cause a no shut off and all kinds of problems. It's available from GM for about $35 and I think a complete motor with the board is like $120 brand new.
