JTraik
08-13-09, 03:22 AM
'95 FWB 72k
I am pretty sure my shocks have seen better days however I have no frame of reference to determine for sure if they are actually bad. I have only driven the car 5000 miles in the two years I have owned it and I have gone through everything in the entire car to make sure it is in top working order, the suspension was the next project. I bought the car and drove it for sometime until learning the air pump for the rear shocks had a blown fuse, installed new fuse and the leveling system has been working excellent ever since, shocks hold air very well. I have noticed on the occasions that I have had the vehicle on the lift that there seems to be a oily residue on one of the shocks which would indicate blown I am pretty sure. However the rest of the shocks are quite dry.
By rocking the front and back bumpers the vehicle will oscillate a few times before it comes to a rest, and it is VERY easy to push the car up and down, much more than I ever remember in my 9c1 ( I do understand the significant suspension difference between the two, but they seem VASTLY different from each other) . The vehicle does not oscillate freely as if there was no shock dampening at all but again it will do it a few times before it comes to a stop.
As for driving it is very thuddy over rough road but again does not constantly rock after encountering a bump/dip. Turning corners is only enjoyable at very slow speeds and if there is any bumps rounding the corner its kind of unpleasant.
If they are blown I was looking to get all AC-Delco OEM stuff, assuming that it will give a responsive ride without sacrificing much of the cushy Cadillac feel that I have been so accustomed to over smooth road.
Your input as to how bad you think my shocks may actually be is greatly appreciated. Because again I really have no understanding as to what everything SHOULD be feeling like. And if you have any suggestions on other shocks that would give me the ride I am looking for, that would be awesome. I just figured that I couldnt go wrong with OEM type shocks however I do understand there is a bit of adapting that has to be done to utilize newer air shocks with the air pump lines.
Thanks much,
- Jeff
Thanks much,
- Jeff
