CJPC
08-12-09, 11:52 PM
Finally got some free time in ages to fix up my 92 Brougham, for starters the Drivers window, the motor gave out a while back, and got a new motor for it.
So, after pulling the panel, drilling out the rivets, disconnecting the motor from the regulator with a few painful (to me, too many cuts) to access screws + bolts - pulled it out. Stuck in the new one, thing didn't work. It also did not work disconnected (power only) - my luck, got it a few months back, so much on the return. Anywho, buy a new motor, stick it in - only to find out my window regulator tape is all eaten up.
Ok, not too much of a problem - hit the auto stores - nobody has it (you know, because 1992 is just too old I suppose). Order it online, comes today. Put it in, things are going great, motor sucks the tape in and through fine.
One note, when removing the track stop thingy (on the track side), took me quite a bit to realize I was doing it wrong, jam a screwdriver into the right side, while you push down on it, wihle at the same time, pulling up on it (its odd, yeah, but if you are doing it, you will get it)
Anywho, get the tape installed, go to move the window, it moves less than 1 inch.
Idiotically, I forgot to leave any room for the window to open, no play in the tape. Such a stupid move - luckily have new tape coming tomorrow (just a waste of $$ and time)
Bit of a read, but, needed a good story to go along with it.
Any who, planned for this week for additional to-do's.
Need to fix my ABS, throwing wheel speed sensor errors (front left + right), but the sensors check good (~1100 ohms) , hoping for a bad connection at the ABS module, but not too sure.
Also have new rear shocks coming (max-air), got a good price on them - any comments/advice?
Finally need to start by replacing my plugs (they are always a pain with big arms, "lankyness" would be helpful), thinking of getting AC Delco rapidfires, got a coupon too (always good to get a discount!)
Thanks!
Thanks!
