View Full Version : New code? creeker 08-12-09, 05:14 PM I am getting a E-52 code on my 92 sdv., PCM memory reset,it also says
"reset,see note" I couldn't find a note, I disconnected my battery a few days ago for about half an hour,could this have caused this reading?.
What does pcm mean?, thanks Cream_Devil_91 08-12-09, 05:58 PM If the battery has been disconnected for any purpose, code E52 will set. The PCM/ECM keeps a running check on the memory, if memory changes, it resets.
PCM/ECM = Powertrain Control Module / Engine Control Module
Completely harmless... creeker 08-12-09, 06:36 PM If the battery has been disconnected for any purpose, code E52 will set. The PCM/ECM keeps a running check on the memory, if memory changes, it resets.
Thanks for reply,I was getting an E-31 and E-74 readout before,(I know what they mean) would this new E-52 be blocking these readings?,what I'm getting at, are 31 and 74 still probably valid?.How do I erase 52 to clear readout display,so that I can see if 31 and 54 are still valid. Cream_Devil_91 08-12-09, 07:30 PM There's no way to know now whether they were stored in history or were current, but they will show up again if the problem is still there...
Have you driven it much since you unhooked the battery?
To clear codes, wait till the end and press and hold OFF and HI on the climate control... creeker 08-12-09, 08:23 PM There's no way to know now whether they were stored in history or were current, but they will show up again if the problem is still there...
No , I haven't driven the car since, I will try again to clear with Off and HI, or should it be driven?. creeker 08-12-09, 08:33 PM No , I haven't driven the car since, I will try again to clear with Off and HI, or should it be driven?.
I have another code now, E-95, E-95 isn't even on the list, any idea what it is?. Cream_Devil_91 08-12-09, 09:37 PM Ok lets start over, put the keys in and run your diagnostics...
At the end it should show .7.0 , if you want to clear your codes press and hold OFF and HI until E.0.0 shows, now your codes are cleared...
Your "E95" is probably E.9.5 - check it again - you must have pushed HI only or didn't push them both at the same time... creeker 08-12-09, 11:51 PM Ok lets start over, put the keys in and run your diagnostics...
Yes,it came up E.0.0, thanks for help. | |
