: sub and amp hook up
08-10-09, 09:49 PM
is there an aux output on the back of the factory nav/radio to hook up an amp or do i need a line out converter?
08-10-09, 11:35 PM
There is no output on the back of the NAV/Radio. I don't think there is one on the stock amp in the trunk either.
08-11-09, 09:06 AM
Yes you will need a converter and in addition to that you are going to need a crossover as well for your amp. If you don't install one your subs are going to sound really low, the added base won't even be worth it. The factory output voltage is so low that the amp really can't improve the base that much so don't kid yourself you will need a crossover, or something to amplify the signal from the converter.
08-11-09, 03:52 PM
A line Driver
