View Full Version : How to Instructions - Transmission Fluid Change
StealthV
07-24-04, 06:42 PM
Changed the transmission fluid today on my V @ 2150 miles. Here's the process to do-it-yourself!
1. Items Required:
-- Four quarts of Dextron III Automatic Transmission Fluid (for mine I used Mobil1 ATF).
-- Fluid pump (make sure the threads are big enough for the Mobil1 bottle) or a suction gun would also work well
-- Oil drain pan
-- Set of Rhino ramps or equivalent
-- 7/8" wrench
-- 3/8" ratchet
-- Roll of teflon tape
-- Creeper to roll under car
-- Troublelight to see in the dark :coolgleam
-- One CTS-V (most important part!)
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange01.jpg
2. Before the oil change, drive at least 10-15 miles to warm the transmission fluid up to at least 150 degrees.
While working under the car, the engine, transmission and exhaust will be extremely hot. Be careful, safety first!
3. With the V safely supported, remove the fill plug on the driver's side of the transmission with the 3/8" ratchet. The fill plug is half-way up the side of the transmission, near the orange "Use Dextron III ATF Only" sticker and CAGS harness.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange02.jpg
4. On the passenger side of the V, locate the transmission temperature sensor. It is located on the RH side at the lower rear of the transmission. Disconnect the transmission temperature sensor harness and place the end of the harness behind the transmission's serial number tag to prevent the harness from being melted on the hot exhaust pipe.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange03.jpg
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange04.jpg
5. Slide the oil drain pan under the V and with the 7/8" wrench, remove the temperature sensor.
Caution! Hot oil will come out quickly and also splash on the passenger side exhaust pipe!
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange05.jpg
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange06.jpg
6. While the fluid is draining, clean up the temperature sensor.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange07.jpg
7. Apply several wraps of teflon tape around the threads of the sensor. Make sure to wrap it the correct direction. Suggest holding the tape in your left hand, the sensor in your right. Place the tape on top of the sensor threads and rotate the sensor clockwise with your right hand. This will put the tape on in the same direction as the threads are cut.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange08.jpg
8. Once the fluid is done draining, clean up the transmission of any fluid that may have dripped out around the hole.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange09.jpg
9. Thread in the temperature sensor and tighten until it is just snug with the 7/8" wrench.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange10.jpg
10. Reconnect the temperature sensor harness.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange11.jpg
11. Clean the fill plug and wrap with teflon tape, similar to step 7.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange16.jpg
12. Use a fluid pump (or a suction gun) to pump the fluid into the fill hole on the driver's side.
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange12.jpg
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange13.jpg
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange14.jpg
13. Fill the transmission more slowly when you get about half way through your 4th quart of fluid. Continue to fill until fluid begins to run out of the fill hole. Here's the puddle of fluid I had on the floor after "knowing" it was full. :)
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange15.jpg
14. Insert the plug and tighten until just snug with the 3/8" ratchet.
15. Clean up your mess, safely lower the V and take it for a spin and enjoy the knowledge that for not much money, you've done your transmission a favor! :worship: V
16. Here's the comparison in color between the factory fill and the Mobil1. Hate to see what this would look like after 100,000 miles since GM says it is "filled for life." (Yes Reed, you can put it on the FAQ) :cheers:
http://www.nitro-nights.com/2005v/t-56/vtransfluidchange17.jpg
Dreamin
07-25-04, 03:40 AM
Excellent work StealthV... same comment as diff writeup, highlight that fill plug should be removed first. And you may also want to highlight: Dextron III Automatic Transmission Fluid in step 1.
FWIW, the technical specialists / guru's on the Z6 forum advise waiting until 5000 miles before switching to *synthetic* tranny fluid, to make sure the syncho's are fully broken-in.
Here is some data on the various ATF's
http://zeemr.home.comcast.net/ATF.gif
Dreamin
07-25-04, 03:42 AM
And here is a "zoomed-out" pic showing both fill (above Dextron III sticker) and drain plugs (lower right of pic).
Note the exposed threads on the plugs (factory orange thread compound)... as posted, "tighten until snug"... no need to waste on the plugs.
http://zeemr.home.comcast.net/tranny.jpg
StealthV
07-25-04, 12:35 PM
Good point on the 5,000 mile switch over to synthetic. For the past several years, I've been lurking on the Z06 forum as my first choice in a new car was a Z06, the V was a comprimise with the wife.
It is interesting to follow the debates - some have changed earlier than 5,000 and had no problems and others swear to wait. For my early switch-over to synthetic ATF, I'll be one of the guinea pigs for us V owners. :drinker
That's a great picture of the trans up while it is up on the lift, if you don't mind, I'd like to add some of the magic arrows to it and use it in the instructions. :cheers:
Dreamin
07-25-04, 03:06 PM
Stealth, and to anyone else, always feel free to use any of my pics!
urbanski
08-01-04, 02:01 PM
Awesome!!
Many thanks! :D:D
