startlookin
08-10-09, 08:53 PM
Hello all! New to the forum.....I thought maybe I can get some assitance on this problem. I am working on a 1990 Seville with the digital cluster. A friend owns it. Hasn't had it but for a couple months, but had the fuel pump replaced 2 weeks after purchase. 2 weeks later the lighting for the cluster and a/c panel started going out, and back in. He said a fuse finally popped, and replaced it with another of the same rating. Now there is no illumination in the cluster or the a/c panel. I have checked the central power supply and plug, seems fine. Actually took it apart, it only has 3 points of esting on the circiut board. Has many wires, but where they solder onto the board, there is one main ground tying at least 6 points together, a 12v source, tying about 6 points, and a outlet 7v signal going out to about 6 points. the cluster and a/c panel both have a wire with the same voltage. Both have good grounds. I disassembled and cleaned the twighlight/headlight switch. All fuses are good. What could cause both units to go out when all fuses are good?
