scetch50
07-24-04, 04:38 AM
I just got a new 95 eldorado touring coupe. I have a 1 month old pioneer dvd/cd deck from my last car that i would like to install in my new caddy. Is this relativley easy or should i go through a professional. I installed it myslef last time but i understand that the caddy has a bose system and i suspect that the door speakers have individual amps therefore it may be considerably harder.
adamym86
08-05-04, 09:47 PM
Hey man,
Even though that I'm only 18 I have successfully completed installing an aftermarket deck in my '94 eldorado. No, it's not hard at all, but the easiest way to do it is to completley bypass the stock system. so you'll have to run wire. The wires are easy to run, just under the side panels for the carpet. Other than a lot of wire and a bit more time than your use to it's an easy installation.
Or, if you want the more spendy way, but for sure way to work, there's an adapter that run's for money that's out of my budget.
If you need any tips on how to install subs and or amps just send me a line.
Hey i need help rewiring my '94 STS seville with bose, Need to do a deck and speaker installation and dont know the wire coordinatin, help on the full wire diagram would be great. thanks
Eldyfig
08-15-04, 12:05 PM
Here is a good link to help you along also:
http://carstereohelp.com/strcadillac.htm
