: tire size
djnash
08-05-09, 09:51 AM
I know this has been brought up but i couldn't find the thread. 05 STS. someone had put the same size on all 4 rims 255? anyone remember? I am looking for tires and rims:worship:
EChas3
08-05-09, 12:52 PM
I think there are staggered tires on 17" wheels that are different width. The 18" OEM staggered tires can be replaced with 255's all around.
AllGoNShow
08-07-09, 11:57 AM
Correct, 17" wheels are staggared. Need to run staggered setup on them. You can switch to same size all around but it will look retarded on the rims in the rear. If anything run 225's all the way around for winter and staggared setup for summer.
EChas3
08-07-09, 01:05 PM
I think it is important to note that some 17" wheels are staggered widths and the tires therefore do need to be staggered, too. Other 17" are the same width all-around and this is not an issue.
I don't believe any of the 18" wheels require staggered tires. In all cases, refer to the tire information badge on the edge of the drivers door or sill.
D&Ds_STS
08-07-09, 02:47 PM
I want to change to 255/45-18s on the front next time I need tires so I can rotate them. Will there be any noticeable difference in handling with the wider tires?
EChas3
08-08-09, 07:54 PM
Better when hot & dry, worse when cold & wet.
