View Full Version : Strut leaking fluid
turnerbend
08-04-09, 06:48 PM
Have anybody had a strut to leak fluid? What would cause this?
Right front strut on 05 STS is leaking. Dealer said they could get to it on Thursday.
submariner409
08-05-09, 03:01 PM
Strut leaks are not too common, but essentially the same as a shock fluid leak. A boot or seal has failed.
abs
08-15-09, 03:44 PM
It may very well be a bad seal around the piston. This happens over time as the seal can wear and deteriorate. Also, struts can heat up, particularly at the seal interface. I have a rear strut on my '99 Deville that is leaking and will be replaced in the next week or two. The important thing is to always replace struts in pairs - both rear or both front - at a minimum. Usually, if one is worn enough to start leaking, it implies the rest may soon also require replacement. If it were me, I'd do all four.
Andrew
ewill3rd
08-15-09, 11:41 PM
Technically I believe that is a "shock", but regardless... if it is leaking then it is just bad.
Things break.
No it is not a common failure.
submariner409
08-16-09, 08:23 AM
Electronically controlled MacPherson struts in front, electronically controlled and/or air-assisted shocks in back.
ewill3rd
08-16-09, 01:44 PM
Not to argue with you sub but an '05 STS is RWD and it does use a coil over shock in the front and shocks in the back.
(I took a moment to look it up) ;)
submariner409
08-16-09, 02:03 PM
I'm stuck in the Seville ( the real STS) world......my bad. (There still is no rear strut on a 99 Deville, however.............Post #3)
ewill3rd
08-16-09, 06:24 PM
I usually don't gripe... if someone says strut and it is a shock or vice versa I know what they are talking about... ;)
turnerbend
08-22-09, 12:13 AM
It was a shock and dealer said it was defected. Car has less than 11,000 miles.
ewill3rd
08-22-09, 08:42 AM
Failures are rare, but not unheard of.
Glad it is fixed.
osu411yamaha
09-01-09, 03:59 AM
2005 with only 11k? Get that car out and enjoy it!!!!:)
