View Full Version : '94 Fleetwood load level system adjustment
scurling
07-23-04, 05:16 PM
Does someone know if I can adjust the leveling system to compensate for an installed trailer hitch. I scrape the hitch with each driveway dip I go over. My '86 Olds had an adjustable link on the trailing arm of the right-rear wheel assembly, but I don't see any way to make adjustments on the Fleetwood.
juiceE
07-27-04, 04:51 PM
u can adjust the sensor on the control arm
caddyfleetwoodca
07-28-04, 09:46 PM
on the passenger side rear upper control arm there is a rod that you unclip and twist which adjusts the height that the air shocks are inflated to.
