: coolant low light question
08-01-09, 09:19 PM
ok whenever i get in my car after it sits up a few hours, mainly i goto bed, wake up jump in the car.
the "coolant low" light is on while the car is running. if i rev the car up it goes off and comes on when the rpms come back down. now when i drive it it stays on for maybe half a block then its fine till it sits a while again.
coolant level is fine
any ideas, o yea its a 1995 fleetwood
08-02-09, 11:33 PM
If your sensor is telling you are low on coolant and you are not low... I'm betting your sensor is bad... you can unplug it to keep the light off .. or get a new sensor... its on the bottom of the coolant filler bottle....
08-03-09, 07:19 PM
preciate it, it does go off you just have to drive the car about half a block before it does go off. only problem ive had with the car so far
