: OBD Plug location on 2005 STS ?
07-29-09, 08:16 PM
Anyone have a clue where the OBD connector is on a 2005 STS,W/1SE pkg.
I don't see it under the steering wheel.
Correct me if I am wrong, if the plug fits, from the OBD reader,
to the car,then it is the correct OBD reader ?
Spencer's HIDs
07-29-09, 08:18 PM
negative. all connectors are the same 96 and newer, its mandated for obd-2. it should be under the dash on the drivers side. i've seen them in the glove box, but i'd look around under the dash on the drivers side some more
07-29-09, 11:55 PM
It is directly above the parking brake pedal with the connector facing down,
07-30-09, 12:25 AM
Thankx guys, WILL check tomorrow !
07-30-09, 08:32 PM
Thankx guys, on mine it is above the emergency brake, way up into the dash.
Thanks for the info ! You got to really get down to see it. :eek:
07-31-09, 12:37 AM
Any scantool will have to be CAN enabled.
