View Full Version : 06 3.6L Strut brace Incognito 07-23-09, 07:42 PM Bought a strut tower brace for my 06 3.6L. Installed today and went for a long winding drive. I noticed a substantial difference in the way the car handled.
bought on Ebay fron=m Big Daddy Caddy for $199
Good upgrade accessory. Good deal. scoundrel111 02-18-10, 04:54 PM Hows this working out for you? I just saw the same one from him on ebay, is it worth it? cvadala7813 02-19-10, 01:19 PM I wanted to get one of these but I have an early model 04 and the heat protector under the hood is not shaped for the brace. Has anyone does this with an 03-04? Kingoftypos 02-19-10, 01:25 PM Bought a strut tower brace for my 06 3.6L. Installed today and went for a long winding drive. I noticed a substantial difference in the way the car handled.
Can you show some pictures?
KOT chevyhighperformance 02-19-10, 06:40 PM I wanted to get one of these but I have an early model 04 and the heat protector under the hood is not shaped for the brace. Has anyone does this with an 03-04?
We have an early 04, and I had to modify the stb to fit. I ground the welds off that hold bar to the perches. I flattened out the bar, and re-welded the bar to the perches. cvadala7813 02-19-10, 11:10 PM Has anyone successfully changed the old hood liner for a newer model liner and installed the tower brace? I have search the tread and it seems like the 3.2L had issues with clearance even after the swap. Is there any 3.6L swaps that were successful? chevyhighperformance 02-20-10, 10:19 AM Has anyone successfully changed the old hood liner for a newer model liner and installed the tower brace? I have search the tread and it seems like the 3.2L had issues with clearance even after the swap. Is there any 3.6L swaps that were successful?
The real issue is that the bottom metal of the hood will contact the STB and not let you close the hood. The hood on the newer models have an indentation for the STB and lets the hood close. I think one person cut the underside hood bracing to let the STB fit, there may have been custom ones made, and what I did posted above. ghettomike 02-20-10, 10:33 AM if there is a stb that will work on the 03 hood i would love to know about it. txbest1980 02-20-10, 10:48 AM the V one fits, just with a different hood...i can confirm that for sure, cause i have that tommy compton 02-20-10, 06:22 PM if there is a stb that will work on the 03 hood i would love to know about it.
This one does, but good luck finding one. I had this on my CTS then swapped it to my V. They were made when CTS was first manufactured sold by Vouge and manufactured by Lund. They stopped manufacturing them after a short production run, I think Vouge may still have them listed on their site though.
I was fortunate to buy it off a pevious member here. You may also want to check out BMR they have a strut brace that may fit, however it is mucho denero.
http://i36.photobucket.com/albums/e29/tommycompton/my%20rig/newcase/covers1.jpg txbest1980 02-20-10, 06:29 PM damn tommy, that is a clean looking STB...
also, can you post a link to the website you are referring to where it may be? cause i am coming up with nothing tommy compton 02-20-10, 06:36 PM Vouge, you may have to find an authourized vouge dealer.
http://www.voguetyre.com/products/accessories/full.php?ProductID=0000001251&Cat=4&Make=Cadillac&Model=CTS&Year=2003&View=
BMR
http://www.bmrfabrication.com/CTS-Vpage.htm tommy compton 02-20-10, 06:39 PM Vouge, you may have to find an authourized vouge dealer.
BMR
http://www.bmrfabrication.com/CTS-Vpage.htm txbest1980 02-20-10, 06:43 PM thanks tommy...you are always helpful
did yours come with the CTS on there or did you put that on. the one you linked me to looks like it has the holes all the way across...yours looks better, but the one they have is nice too cvadala7813 02-21-10, 02:13 AM This one does, but good luck finding one. I had this on my CTS then swapped it to my V. They were made when CTS was first manufactured sold by Vouge and manufactured by Lund. They stopped manufacturing them after a short production run, I think Vouge may still have them listed on their site though.
So this Brace will fit without any modification? That looks sick too! tommy compton 02-21-10, 01:50 PM thanks tommy...you are always helpful
Ya the CTS I put on. It looks like your right about the holes I never noticed that before, I'm not sure if they changed design or if maybe the Lund an Vouge are two different bars.
Yes direct fit on the 3.2l engine, not sure but I'm guessing it would fit the 3.6l.
If it is infact made by Lund I don't think they make parts for the CTS anymore. Your best bet would be to try and get hold of Vouge, or luck out and find one used, but they are uber rare.
I'm not sure about the BMR and fitting the 3.2 and 3.6, and/or 3.2 hood clearance issues you may have to ask them. I know the V ls engines sit lower than the 3.2l by quite abit. ghettomike 02-26-10, 06:52 PM tommy do you have any pictures of the stb on the 3.2L?
what is the shape of it? i found a couple flat ones, if they line up on my towers i can take the brace into work and have it bent on the pipe bender hopefully. unless its completely flat across?
this one is adjustable length probably about 4 inches on each end. tommy compton 02-27-10, 12:57 PM Sorry I don't have any pics on the 3.2l. It does have a bow to it though heres' another angle on it.
http://i36.photobucket.com/albums/e29/tommycompton/my%20rig/newcase/covers3.jpg
http://i36.photobucket.com/albums/e29/tommycompton/my%20rig/newcase/covers.jpg
On the 3.2l the bar just clears the top, if you have the updated PCV it just rubs it ever so slightly, it's a tight fit between the brace and the hood also. |
