View Full Version : How To Remove Sub Woofer Screen?
62Jeff
07-23-09, 09:37 AM
Greetings,
I've traced the annoying rattle that I thought was in my headliner - to the cover of the sub woofer in the rear package tray.
Anyone have experience with getting access to those parts so I can repair the rattle easily - avoiding the dealership experience?
I'm guessing I would have to pull the rear seats in order to get to mounting hardware for the package tray, but is it possible the sub woofer screen is just a press fit, and that removing it could be as simple as just lifting it out of place?
It seems somewhat flimsy so I don't wish to force anything until I have a better idea.
Jeff
readyact
07-23-09, 04:27 PM
I don't think it's a press fitting. I took a flathead and tried to pry up the screen, but it's not budging. Perhaps it does just pops off, but I decided to quit while I was still ahead. When I had it pried up some it appeared that it is screwed in from the bottom. I know I didnít add much to your dilemma, but I thought Iíd share my observation.
1BlinkGone
07-23-09, 05:11 PM
I'm wondering if you can perhaps wedge some felt or something between the screen and mating surface to mute the rattle; or maybe removing the grille, running a thin bead of silicone along the grille edges, letting it set, and then re-installing it...
62Jeff
07-23-09, 07:31 PM
Thank you for checking. I suspect it is probably screwed in place, with a few screws loose now.
I'm thinking about shoving a folded business card on the left and right sides to see if that cures the rattle, in order to definitively confirm the source of the noise. I'd prefer to pull the car apart and fix it the right way once I know which direction to go. If I determine the grill would vibrate against the woofer surface even if mounted correctly, that changes the solution versus a grill that is simply loose.
Thank you both for your ideas.
Razorecko
07-23-09, 09:32 PM
^ get some window weatherstripping from your local hardware store. Use a credit card to wedge it in there. It will be inconspicuous and it will keep any vibrations/noises at a min
wait4me
07-24-09, 12:30 PM
My WHOLE back panel is what is rattling, it sounds like a broken speaker when i play the radio and well, just drive down the road. It is rather annoying. One day ill get some time and drop the car off to the dealer for the popping noise from the wheels, the squeaks on the headliner and the rattles from the rear panel, and the sticking ricaro buttons on the side of the chair that kill my battery if left stuck. :)
JFJr
07-24-09, 02:12 PM
Check with your dealer. I believe that there is a TSB on it.
62Jeff
07-26-09, 01:03 AM
Thank you all for the suggestions. I'm not quite ready to take it to the dealer, as I plan to use the car next Saturday for a road trip, and I'm assuming the dealer can't touch the car for less than a week's outage (my Jag dealer couldn't).
Anyway, the screen seems to be firmly mounted to the package tray. I had to work hard to force a single business card between the screen and the tray, and it didn't change the rattle qualities.
After looking more closely, it appears the screen is sitting on top of a substructure that includes a honeycomb structure which has dime-sized openings to allow sound to come through.
My current working theory is that the plastic screen is sitting on top of the honeycomb structure, and the two are bumping uglies with each other.
Short of pulling the package tray on my own, I think this one is going to have to involve the dealer. I've tried to locate a TSB but have thus far been unsuccessful.
