Leadergrass
07-22-04, 01:42 AM
Me again (98 STS). I'm not a tech so excuse my stupid question, but I assume that the toothbrush method involves removing the MAF, and if so, will I need a gasket or can I reuse the old one?
Thanks.
Thanks.
| View Full Version : Throttle body cleaning question Leadergrass 07-22-04, 01:42 AM Me again (98 STS). I'm not a tech so excuse my stupid question, but I assume that the toothbrush method involves removing the MAF, and if so, will I need a gasket or can I reuse the old one? Thanks. 97Deville 07-22-04, 06:52 AM Hi, Read this first, http://www.cadillacforums.com/forums/showpost.php?p=107752&postcount=7 Chris Ranger 07-22-04, 09:56 PM I can't recall if there is a gasket there or not but if there is you should be able to use the old one. Even if the gasket was damaged and had a small leak it would not make much difference in that position. | |
