: What's wrong with my radio?
07-21-09, 01:19 AM
So as you can see the stereo isn't quite functioning properly. I was told by the previous owner that all it needed was a new BCM. Can anybody tell me where to find out? The light fuse was pulled out as the lights stayed on "also because of the BCM. The Fleetwood Guy also let me know that the 1994 Fleetwood Brougham model doesn't contain a BCM module, can anybody tell me what I need? Thanks."
07-21-09, 06:17 PM
This would look pretty slick in your dash, its a double din sized opening like the factory radio, so it'll fill out the whole space. Time to get with it, you can play CD's and hook up your MP3 player to it, plus the sound quality with a set of aftermarket speakers would blow the OEM stuff out of the water.
07-23-09, 06:49 PM
That's nice and all, but I can't see myself spending $300 for a radio.
Anything a bit cheaper that would fit? (I plan to replace mine sometime too, because I want to use my mp3 player with it).
07-23-09, 07:05 PM
I think its a fuse problem. Removing a fuse does not fix a dome light issue. Fuses usually power more than one circuit. Could be caused by that fuse you removed or another one thats blown, keeping the interior lights on. Appears that the "memory" function is not holding a set station. Check all fuses, key on, engine off, with a test light.
