View Full Version : No A/C, cooling fans not working 94 FWB
SDCaddyLacky
07-20-09, 11:07 PM
As always, I like to assume that every fix is an easy one.
Today I filled up the refrigerant, since it was a little low, thought that was my problem, well it didn't do anything.
I don't think the compressor is even coming on, all fuses are good, and I don't see any leaks. The blower motor works, but it blows hot air only.
Also I noticed that the 2 electric fans don't come on, even after driving around in the hot weather. I check the engine temp, and it was hovering around 195 almost 200 degrees at idle. Does anyone know what both problems could be?
Thanks so much.
csbuckn
07-20-09, 11:27 PM
I'm not sure but I think it has a fail safe if you overfill it. Search some of the other AC threads to see what they said. I believe there was a post about a similar issue. I think it came down to something about overfilling it.
