: '96 Deville Coolant Change
386 DeVille
07-19-09, 01:17 AM
Hey guys. It's come time for me to change my coolant in my '96 Deville at 150k+. I have been researching about using the coolant tablets, however, I am finding conflicting stories. Am I to use the coolant sealant tablets or not?
On a side note, I have a problem with the oil level warning on the dash when the oil level is fine. Also, the oil pressure light flashes sometimes at idle. Any ideas on these? Anybody know where to get the oil level sensor for a good price?
Ranger
07-19-09, 10:39 AM
GM quit using the tabs in about '02. So did I. Whether you use then is up to you. No damage will be caused if you don't.
Sounds like you need an oil level sensor and maybe a pressure switch as well. Check http://www.rockauto.com. Use A/C Delco parts.
386 DeVille
07-19-09, 01:04 PM
Thanks Ranger. I was just telling my fiance, you would be the one to respond.
