: Air ride compressor
egheorghe
07-13-09, 11:43 PM
Hi there,
I had just replaced the air ride compressor with a used one, but not it takes kind of long for the car to rise to the right level. Do you think it might be something i did wrong or there is a air leak that caused the other compressor to brake and the problem is still there?
What should I check first? When there is 3 people on the back seat the compressor works for several minutes. Is that normal? Maybe I just pay too much attention to it now.....
Thanks!
Submariner409
07-14-09, 09:27 AM
If the compressor assembly levels the car and shuts off, that's OK. If it cycles on and off, even every 5 minutes, you have a slow leak.
Actually, it should take no more than 15 - 20 seconds to adjust level.
egheorghe
07-14-09, 04:50 PM
Thank you!
Well it brings the car at the right level, but I think it takes too long.
Do you know if there is a certain pressure that the compressor should pump out air and how/if I can check that?
AlBundy
07-14-09, 04:52 PM
Did you check for codes?
egheorghe
07-14-09, 11:47 PM
No codes
tateos
07-15-09, 08:12 PM
The replacement pump could be worn and weak.
Also, the pump usually wears out as a result of a leak that caused the original compressor to overwork.
Two possibilities.
egheorghe
07-15-09, 08:29 PM
Thank you guys!
I'll try to see if there is a leak in the system.
OOoo, another question: Is it possible that the shocks are loosing air or just the air lines?
Submariner409
07-15-09, 09:13 PM
Use the tried and true technique of getting the car up on a lift, start the engine and level the car. Shut down and spray a soap solution over the shocks and lines. Bubbles ??? Leak. You may have to trace the problem all the way back to the compressor connector.
