cowboycadillac556
07-12-09, 08:40 PM
Iam working on a 74 472 and am wondering what puller I need to get the crank pulley off?
| View Full Version : help cowboycadillac556 07-12-09, 08:40 PM Iam working on a 74 472 and am wondering what puller I need to get the crank pulley off? BRUCE ROE 07-12-09, 09:48 PM I used a standard steering wheel puller on my 500. Be sure it doesn't drop into the threaded center hole & mess up the threads. You will need those threads and a special puller/installer to put it back. Bruce Roe CLC # 14630 cowboycadillac556 07-12-09, 09:57 PM well the next question is what is the installer consist of ? or maybe where could i get my hands on one? BRUCE ROE 07-14-09, 01:35 AM A MOROSO harmonic balancer installation tool MOR61744 $44.49 looks like the one I bought years ago from JCW at half the price. Maybe you can find a better deal; its a good tool with adapters for different engines. You will need a couple of big wrenches to use it. Bruce Roe cowboycadillac556 07-14-09, 02:53 PM thank you very much Bruce Roe BRUCE ROE 07-14-09, 07:10 PM OK, I looked at my damper tool. My JCW tool had 8 thread in adapters, for 7/16-20, 1/2-20, 5/8-18, 3/4-16, 9/16-18, M16-2.0, M14-1.50, M12-1.50. The MOROSO only covered the first 4. I used the M14-1.50 on a Cad 500. Maybe there is a better & more universal damper installer out there. Bruce Roe CLC #14630 steelybill 07-15-09, 01:45 AM Some auto stores rent the tools to do that with. Whatever you do, don't use a hammer to put the balancer back on. If you buy a good universal damper removal/installer set, it will work on most engines. | |
