: HELP where and what color is vss wire under dash pad
cadillacnick99sls
07-08-09, 09:30 PM
:hmm:whats up people, I have the nav antenna plugged and run the plug from sts2003 factory nav , dont know what color is the vss wire and its location. I have 1999 sls . dash pad is off . PLEASE HELP CAR IS IN PIECES. also is the nav antenna gonna work by my rearview mirror? what would be the best place?
N*Caddy
07-08-09, 09:54 PM
If you have a DK GRN/WH wire on F4 that's the VSS. If not then you have to grab one from the IPC or from the CVRSS module. In either case should be connected to F2. CadillacSTS2003 should be able to give you the help you need. The standard location for the GPS antenna is under the dash pad (I think). But you can connect-it anywhere as long as is not under a metal piece (metal piece includes roof too).
cadillacnick99sls
07-08-09, 10:04 PM
cant reach him. ill check thurs afterwork for green wire . f4? what is that. ipc? cvrss? not good with this . thx for the help n*. just trying to get this done with.
N*Caddy
07-08-09, 10:24 PM
F4 is on the HU connector, 4 pins away from the ORN wire (on the same row).
IPC is the speedometer cluster
CVRSS is the module controlling the suspension (and some stability feature) located on the right side of the electronics bay.
CadillacSTS42005
07-08-09, 10:30 PM
yup
email is the best way to reach me
itll be on the cluster on the top plug on the left hand side
its the only green wire with white stripe on it
cadillacnick99sls
07-08-09, 10:48 PM
yup
THE EMAIL I HAVE /1997? i sent u an email with no reply .
CadillacSTS42005
07-08-09, 10:56 PM
cadillac1997etc@yahoo.com?
cadillacnick99sls
07-09-09, 06:21 PM
thx n*
