c5 rv
07-07-09, 01:18 PM
I got a left taillight / brake light message yesterday and eventually resolved the problem by replacing the outside left rear bulb with a 2057. Some questions, though:
- I originally thought the problem was with the inner bulb. However, that is not a 2057. It has a single filament. The owner's manual and O'Reillys both said it should be a 2057. I replaced it with the same bulb that was installed. (1037 or something like that.) Is that not a brake / turn signal light?
- The Allante facts and other posts state that brass, not tin, based bulbs should be used. Why brass? Is this due to heat buildup? The stores only seem to stock bulbs with silver bases.
- The old bulb appeared fine and the blinkers worked on the outside of the car. However, the blinkers did not work or chime inside the car. Is this normal when the car detects a blinker problem? The new bulb fixed everything.
