View Full Version : Put 20 inch rims on.....(Pics) Now have a small vibration... Please advise...
DTS_BOI
06-27-09, 03:44 AM
I have an STS V-8. It has 35K miles on it. I recently put these 20 inch Arelli rims on the car. The rims are 5X115 bolt pattern, and Im even using hub centric rings. The tires are 255-35-20. Im running about 42 psi in the front tires since they are kinda skinny......
http://i468.photobucket.com/albums/rr43/Vic_Fabuless/66b738a8.jpg
http://i468.photobucket.com/albums/rr43/Vic_Fabuless/c006c624.jpg
http://i468.photobucket.com/albums/rr43/Vic_Fabuless/59b9a1f6.jpg
My problem is that Im getting a small vibration and harshness in the front area of my car between 1o-30 mph. I feel it everytime I accellerate from a stop. The vibration is only up front, and I feel it through the brake pedal and through the floor of the car up front. Also, when Im stopping between 30 and 15 mph the brake pedal feels like its scraping something rough.
These vibration problems did not occur until I put these wheels on. Any ideas? Should I have them re-balanced?
Thanks in advance!
ifmracin
06-27-09, 10:59 AM
Did you get the car re-alligned after putting the new ones on?
and i would say yes to the re-balance.
K STS
06-27-09, 12:08 PM
those wheels look horrible.
but nice color.
AllGoNShow
06-27-09, 12:26 PM
Are you feeling it more through the steering wheel? If you have a vibration/balance problem on the front wheels only, you will feel it through the steering wheel. If you have warped rotors or suspension issues, you will feel it through the brake pedal when you touch it. If you have vibration/balance problem in the rear, you will feel it through your seat and the chassis of the car.
Re-balance all 4 wheels and go from there.
trackbait
06-27-09, 12:38 PM
My bet is on the offset of the new wheels. Did you verify the offset was the same or at least fully compatible with manf specs or OEM wheels?
Measure from your original inside wheel rim to the wheel hub. Don't measure from the tire to the hub. You can use a yard stick or something else that can easily be cut so that the horizontal stick lays on the wheels metal rim. Then measure down to the hub.
Do the same thing on the new wheels. If is more than 1/4 inch different that could easily explain the whole thing, especially the braking. That was the first clue I picked up on.
next2pool
06-27-09, 12:42 PM
First of all, I think your car looks great! Tire balance will not show up at such a low speed so it most likely is runout. I would jack up the front and turn the wheels by hand to see if they have any visible runout or if you feel and hear any interference--it's quite possible that you are rubbing on a caliper. It's very unlikey that alignment can cause this either. Another potential problem during tire changes is that the rotors can get warped if the wheels are over torqued. If the fronts and rears are the same size, you may want to switch them to see what happens. I also think your front pressures are too high. Look on the sidewall and see if there is a max weight rating--that will determine the correct pressure--or look up the brand and size and see what the weight rating is. Good luck!
WillySTS
06-27-09, 01:13 PM
I would go with what he said except for the bit about the rotors. Our rotors slide on over the lugs which are mounted to the hub. The rotor bears no stress from wheel tightening. However that does not mean wheel lug overtightening cannot be an issue, the hub can be distorted as well.
next2pool
06-27-09, 01:25 PM
BTW, I made some of the same appearance mods as you did, although it's a bit tougher to see on a silver car:
http://www.cadillacforums.com/forums/cadillac-sts-forum-2005-through-2010/104756-show-us-your-sts-14.html#post1900502
AllGoNShow
06-27-09, 01:25 PM
How do the rotors have no stress? The rotor sits in between the hub and the wheel. If you crank one bolt on the wheel at 150 ft lb, and the other at 90, you are putting stress on that part of the rim, the rotor between the rim and the hub.
next2pool
06-27-09, 01:28 PM
You're correct about the rotors, but as you say, the hubs in this case can get distorted taking the rotors with them. This has been a huge issue for GM and others and it took us a while to figure out what really was happening. Most high volume tire dealers are now much more carefull
when it comes to tightening the wheels.
KARL DAHLEN
06-27-09, 04:25 PM
Put the original wheels that back on that the car was engineered for!
turnerbend
06-27-09, 08:09 PM
I got a new set of 20" in my storage building now because of the same situation. If you are going to run 20" with the low profile tires, learn to live with the vibration, noise and rough ride. That is the price you pay for that setup.
dkozloski
06-27-09, 09:59 PM
42 PSI is an awful lot of air for a road car. Backoff to about 32PSI and see if it makes a difference.
trackbait
06-27-09, 11:08 PM
I think that is stretching it a bit (not to intend a pun), but warping a hub by even as much as 150 ft lbs of toque would be negligible at best. More likely is the stud would break off before having anything to do with the hub/rotor deflections.
next2pool
06-27-09, 11:29 PM
What you say certainly would sound logical, but unfortunately most of these components are designed right at the limit of performance requirements--mostly due to mass targets. The industry has replaced millions of rotors due to deformation as a result of over torquing.
WillySTS
06-29-09, 11:18 AM
We haven't...and the measurements taken on cars with slide on warped rotors don't bear this out. I had a 2002 Firehawk and had to machine the rotors every 6,000 miles no mater how I put the wheels on(hand tightened with a torque wrench) myself. The rotors warp due to the way they are used and the material they are made off. My rotors did not stop warping until I put a set of "cryoed" rotors on. Then I went 17,000 miles with no problems from them.
The industry does a lot of things that are unecessay,(3,000 mile oil changes come to mind).:bighead:
next2pool
06-29-09, 02:24 PM
[QUOTE=
The industry does a lot of things that are unecessay,(3,000 mile oil changes come to mind).:bighead:[/QUOTE]
That's for sure--it's good old American Marketing genious. In this case it is the aftermarket and dealers ,not the OEM's.
Dougs06sts
06-29-09, 04:23 PM
Come on Karl. How's this man sposed to 'role up and slap da bitches' for his money on 17's ??? :histeric:
GA BuLLDoG
06-30-09, 12:55 AM
I agree. I think it is the rotors. I have 22's on mine but no vibration yet(knock on wood), but when you upgrade to a larger rim like that you should upgrade your barkes as well to compensate. You don't have to, but it helps from problems evolving like this one.
DTS_BOI
07-03-09, 04:26 AM
It not too bad... Im kinda just ignoring it. One day I will have them re-balanced. In the mean time, the vibration is not so bad.. My wife doesnt even notice it but I do because Im really critical. If I find out what it is, I will let you guys know. By the way, I re-tightened all the wheels with my torque wrench. I loosened them, the re-tightened them to 100 pounds. Vibration is still there...
I was told that the 35 series low pro tires need more psi because they are so skinny to help avoid pothole damage. I was told to run between 40 and 50 psi by someone on this site with the low pro tires. I will back them down to 35 psi and see what happens...
