: air in cooling system
tito6169
06-26-09, 09:07 PM
hey guys, newbie here. i need to get my 2000 deville to jake in canada about 3 hour ride from me. i need to get the air out of my cooling system so i can make it to jake without overheating. any suggestions on how to get the air out? thanx in advance guys.
Ranger
06-26-09, 10:48 PM
It is self purging. Why do you need to get the car to Jake?
tito6169
06-26-09, 10:58 PM
i need to get the car to jake so he can fix the headgaskets.
Ranger
06-26-09, 11:02 PM
Then you'll never get the air out. It's being pumped in through a breach in the head gasket.
tito6169
06-26-09, 11:09 PM
well it does it once every 2 or 3 months, then i fill the tank and run the engine for a while and usually it seems to run good again for a while.
Ranger
06-26-09, 11:12 PM
That does not sound like a head gasket. What are your symptoms? Have you had it tested to determine that the head gaskets are bad?
tito6169
06-26-09, 11:18 PM
i've been losing coolant but no puddle on ground, took it to dealer because i had no heat and vehicle was overheating. dealer did replace the tank cap. mechanic "burped" the system and took it for a ride but the heat still wasn't good enough and mechanic said it probably was headgasket. no real test yet though.
Ranger
06-26-09, 11:21 PM
Hmm, those could be HG symptoms. I'd get a test kit from NAPA and test the coolant for exhaust gases to be sure.
tito6169
06-26-09, 11:24 PM
think i'll get that tomorrow, but if it is the HG how can i get that air out just so i can get to jake. i don't think it's that bad of problem yet like i said i can usually ride for about 2 or 3 months till it overheats again.
Ranger
06-26-09, 11:27 PM
Like I said it is self purging. Air is automatically purge from the system via the purge line. The problem is that if it is a HG, the engine just keeps pumping more air in.
tito6169
06-26-09, 11:30 PM
gotcha, i'll keep u posted. thanks for the help.
