circlewfarmsinc
07-19-04, 01:38 PM
Hi guys,
I recently purchased a 1953 Studebaker with a 500 caddy engine. The engine is bored .030, has a mild performance cam, edelbrock carb and intake, and sanderson headers. She is very stout and torquey! It was 90 something degrees yesterday afternoon and I got the car out on the road for the first time. We drove for a couple hours and the engine temp stabilized at 210 to 215 running at 60 mph with the ac on. Temp didn't change with the ac off. It got up to 225 occasionally when we stopped at an intersection. I'm concerned that it may get too hot in stop and go traffic. The car has an aluminum griffin radiator (19 x 18 x 3" core) with a electric fan (14.5"). I cannot run an engine driven fan because the top of the water pump pulley is almost to the top of the radiator! The fan runs all of the time at these temps and I don't think it will last long. If these temps are OK I may just have to get a higher temp fan switch? What degree thermostat should I be running? Have any of you tried the Flow-Kooler water pump? I claims to pump 30% more water. What about a waterless coolant? A larger radiator will not fit without major core support modifications, so does anyone have some suggestions?
Thanks,
Dwayne
Thanks,
Dwayne
