View Full Version : Supercharger 2.55 Pulley belt size
TAGZO
06-20-09, 08:23 AM
can someone tell me what is the belt size if I only change the upper pulley? does it take the stock belt?
Thanks
TAGZO
06-20-09, 12:04 PM
guys, can someone help me please? :)
vperl
06-21-09, 01:38 AM
sure, help is their name...
wait4me
06-21-09, 12:16 PM
080653 Gates or napa. It is available also in a Green stipe version on that same part number that is 2 times as good.
TAGZO
06-21-09, 03:22 PM
thanks! :)
So if i change the upper pulley alone the best size is 080653.
And if i change the upper pulley and 5% under pulley together the best size is 080653 (same)?
thanks again :)
CadV
06-21-09, 03:33 PM
thanks! :)
thanks again :)
I am going into the shop tomorrow and I have the 8.5 and doing the 2.55 I would really like to know if 080653 is the right belt because that is what I bought.
I would think they would be different to be honest and I am a little concerned I was told the wrong information.
TAGZO
06-22-09, 03:25 PM
did you get the belt?
CadV
06-22-09, 04:00 PM
I backed out of doing the blower pulley. Shop felt the diameter was off and I am not gonna get into keying it. Gonna buy a 9 or 9.5" ring instead. I did get the isolator on so no more tapping at idle.
RapidRob
06-22-09, 07:11 PM
^^^ What did your shaft look like? Was there a lot of damage? Also, did they re-use the spring, etc. on the new isolator, or did they install it just as it was from W4M?
Thanks.
Rob
CadV
06-22-09, 10:39 PM
Thanks.
Rob
I posted a picture in a thread called Misc Pictures. The wear was bad IMO. I did not use the spring and my car is not tapping anymore at idle.
CadV
06-23-09, 05:03 PM
thanks! :)
thanks again :)
I spoke to Jess and confirmed 080653 fits both.
TAGZO
06-24-09, 08:31 PM
oh! :)
thank you so much :D i will install soon and will let you all know my dyno result.
