Bro-Ham
06-12-09, 10:55 PM
Hi,
On my '79 Sedan deVille every time when I turn on the wipers the "washer fluid" light on the dash always comes on. My fluid reservoir is full. How do I fix this? Thanks!
Dave
The washer tank has a float within it. The contacts rust up. Either replace the float assembly or disconnect the wire plug to it.
Bro-Ham
06-14-09, 10:10 PM
Thank you! I will check it out in the AM and I appreciate your advice! Dave
Bro-Ham
06-17-09, 09:46 PM
Hi,
Today there was a monsoon of BIG thunderstorms and I knew the wipers would need to be activated. Before I went out I disconnected the washer fluid indicator from the tank and also unplugged and re-plugged the connection. I turned on the wipers and the "WASHER FLUID" light did not come on!!!! THANKS for the advice.
Dave
