View Full Version : CTS Recall
darrelld
07-17-04, 01:09 AM
Could this cause some of the front end shakes I have read here.
Make: CADILLAC
Model: CTS
Year: 2004
Recall Number: 04V273000
Summary:
ON CERTAIN PASSENGER VEHICLES INVOLVED IN THIS CAMPAIGN, THE LOWER CONTROL ARM BALL STUD NUT/WASHER ASSEMBLIES WITH WASHERS WERE MADE OF THE WRONG MATERIAL. THE WASHERS MAY FRACTURE AND BECOME LOOSE OR FALL AWAY FROM THE VEHICLE, REDUCING CLAMP LOAD. SEPARATION OF THE CONTROL ARM BALL STUD AND STEERING KNUCKLE, DUE TO DISENGAGEMENT OF THE TAPERED ATTACHMENT AND RETAINING NUT, IS POSSIBLE.
Consequence:
IF THE CONTROL ARM SEPARATES FROM THE KNUCKLE, THE AFFECTED CORNER OF THE VEHICLE WILL DROP AND THE CONTROL ARM WOULD BE FORCED DOWNWARD, CONTACTING THE WHEEL. THE AFFECTED WHEEL COULD TILT OUTWARD AND CREATE A DRAGGING ACTION THAT WOULD TEND TO SLOW THE VEHICLE AND CREATE A TENDENCY FOR THE VEHICLE TO TURN IN THE DIRECTION OF THE AFFECTED WHEEL. IN EXTREME SITUATIONS, THE AFFECTED WHEEL ASSEMBLY COULD SEPARATE FROM THE VEHICLE. SEPARATION OF THE WHEEL ASSEMBLY WOULD ALSO SEVER THAT WHEEL;S HYDRAULIC BRAKE HOSE AND RESULT IN DIMINISHED BRAKING PERFORMANCE OF THE VEHICLE, WHICH COULD RESULT IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE BALL STUD JOINTS AND MEASURE THE TORQUE OF THE NUT FOR ALL FRONT LOWER CONTROL ARMS IN ALL MODELS AFFECTED AS WELL AS THE REAR LOWER CONTROL ARMS ON THE XLR AND CORVETTE. IF THE TORQUE IS NOT AT SPECIFICATION, THE DEALERS WILL REPLACE THE BALL STUD, THE KNUCKLE, AND THE NUT. IF THE TORQUE IS AT SPECIFICATION, THE DEALERS WILL REPLACE THE NUT/WASHER ASSEMBLY ONLY. THE MANUFACTURER HAS REPORTED THAT OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING THE THIRD QUARTER OF 2004. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2339 OR CHEVROLET AT 1-800-630-2438.
Notes:
GM RECALL NO. 04043. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Or has anyone been notified about this recall;
Make: CADILLAC
Model: CTS
Year: 2004
Recall Number: 03V346000
Summary:
CERTAIN PASSENGER AND SPORT UTILITY VEHICLES FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 207, “SEATING SYSTEMS.” ONE OR BOTH FRONT ANCHOR TABS FOR THE FRONT BUCKET SEATS ARE NOT ENGAGED IN THE FLOOR PAN REINFORCEMENT SLOTS. A SEAT WITH ONLY ONE TAB ENGAGED OR NEITHER ENGAGED WOULD NOT MEET THE STATIC REARWARD LOADING TEST REQUIREMENTS OF THE STANDARD.
Consequence:
IN SOME CRASH CONDITIONS, THE SEAT COULD PIVOT REARWARD AND ITS OCCUPANT OR A REAR SEAT OCCUPANT COULD BE INJURED MORE SEVERELY.
Remedy:
DEALERS WILL ENSURE THAT BOTH FRONT ANCHOR TABS ARE FULLY SEATED IN THE FLOOR PAN REINFORCEMENT SLOTS. OWNER NOTIFICATION BEGAN SEPTEMBER 19, 2003. OWNERS SHOULD CONTACT GM AT 1-800-458-8006.
Notes:
GM RECALL NO. 03050. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
EmersonP123
07-17-04, 01:22 AM
Thats a pretty scary recal.:disappoin :disappoin
Since1980
07-17-04, 02:56 PM
Actually, 4 days ago, I was a victim of the problem of the recall you posted up, DarrellD. Tuesday, I was making a standard routine right turn into my community, and the nut for the control arm (Driver Side) fell off. Basically, the control lodged onto my rim, and scrape it all up. Ironically, when I called Cadillac, they said that my car wasn't under any recalls. They are going to replace everything, but I would advise anyone with a 04 CTS to check their cars. Luckily, I was driving slow, and no accident was caused.
